Hi everyone, I’m new to all of this, but what I want to do is draw a custom shape with grease pencil. After several experiments I was able to draw a line with this:
def modal(self, context, event):
bpy.ops.gpencil.draw(
mode='DRAW',
stroke=[
{"name":"", "location":(0, 0, 0), "mouse":(0,0), "mouse_event":(0,0), "pressure":1, "size":0, "pen_flip":False, "x_tilt":0, "y_tilt":0, "time":0, "is_start":True},
{"name":"", "location":(0, 0, 0), "mouse":(550,150), "mouse_event":(0,0), "pressure":1, "size":0, "pen_flip":False, "x_tilt":0, "y_tilt":0, "time":0, "is_start":False}
wait_for_input=True,
disable_straight=False,
disable_fill=False,
guide_last_angle=0.0)
if event.type in {'RIGHTMOUSE', 'ESC'}:
return {'CANCELLED'}
return {'RUNNING_MODAL'}
The result is several strokes that are continuously drawn on top of each other because the function is executed every time it receives an event.
My questions are: How is this function used?
Is it correct to execute it in the modal () function?
How can I draw, for example an ellipse, as I drag the mouse?
The idea is to create a custom tool similar to the circle tool in grease pencil.
I appreciate any help or tip to better understand all this.
