Oh, actually after another restart it shows a device now! Thank you!
Hello, this tuto didn’t work for me both with Pop os 20.10 and 20.04
I ended up using Ubuntu 20.04 with this tuto : https://rocmdocs.amd.com/en/latest/Installation_Guide/Installation-Guide.html#ubuntu
works great, Blender recognized both my amd cpu and gpu under OpenCL tab.
I followed these instructions as well was not able to get it to work with my 5600xt on PopOS 20.10. After using ./amdgpu-install --no-dkms --opencl=rocm
the command clinfo
wasn’t even available. I had to install in separately and it showed 0 platforms even after restart.
EDIT 1
I also tried uninstall my drivers and installing the 20.40 drivers (per one of the posts) and got this error on executing sudo apt install amdgpu-dkms libdrm-amdgpu-amdgpu1
ERROR (dkms apport): kernel package linux-headers-5.8.0-7630-generic is not supp orted Error! Bad return status for module build on kernel: 5.8.0-7630-generic (amd64) Consult /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/make.log for more infor mation. dpkg: error processing package amdgpu-dkms (--configure): installed amdgpu-dkms package post-installation script subprocess returned erro r exit status 10 Errors were encountered while processing: amdgpu-dkms E: Sub-process /usr/bin/dpkg returned an error code (1)
I get the same error “The amdgpu driver is already installed or was not uninstalled correctly.” As I mentioned in my previous post I tried using your uninstall solution sudo apt install amd-gpu-dkms libdrm-amdgpu-amdgpu1
and got the Bad return status error I Listed above.
EDIT I ran ./amdgpu-install --uninstall
as well and now when I use ./amdgpu-pro-install -y --opencl = pal, Legacy --headless
the output is
E: Invalid operation = ERROR: Unable to install pin package. This driver may not support the running operating system.
Here is the /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/make.log
which provides more info on the error.
DKMS make.log for amdgpu-5.6.20.906300-1164792 for kernel 5.8.0-7630-generic (amd64) Mon Nov 30 08:06:07 PM MST 2020 make: Entering directory '/usr/src/linux-headers-5.8.0-7630-generic' /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/Makefile:20: "Local GCC version 100202 does not match kernel compiler GCC version 100200" /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/Makefile:21: "This may cause unexpected and hard-to-isolate compiler-related issues" AR /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/built-in.a CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/scheduler/sched_main.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/scheduler/sched_fence.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/scheduler/sched_entity.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_memory.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_tt.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/main.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/symbols.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_util.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_memory.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_vm.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_drv.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_device.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_ioctl.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_kms.o /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_vm.c: In function ‘ttm_bo_vm_fault_idle’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_vm.c:76:24: error: ‘struct mm_struct’ has no member named ‘mmap_sem’; did you mean ‘mmap_base’? 76 | up_read(&vma->vm_mm->mmap_sem); | ^~~~~~~~ | mmap_base /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_vm.c: In function ‘amdttm_bo_vm_reserve’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_vm.c:155:26: error: ‘struct mm_struct’ has no member named ‘mmap_sem’; did you mean ‘mmap_base’? 155 | up_read(&vma->vm_mm->mmap_sem); | ^~~~~~~~ | mmap_base make[2]: *** [scripts/Makefile.build:290: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm/ttm_bo_vm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_atombios.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/atombios_crtc.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_device_cgroup.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm_cache.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_fence_array.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_fence.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.o LD [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/scheduler/amd-sched.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/atom.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_io.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_kthread.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_mm.o make[1]: *** [scripts/Makefile.build:519: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/ttm] Error 2 make[1]: *** Waiting for unfinished jobs.... CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_pci.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_perf_event.o /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_kms.c: In function ‘amdgpu_driver_load_kms’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_kms.c:202:38: error: ‘DPM_FLAG_NEVER_SKIP’ undeclared (first use in this function) 202 | dev_pm_set_driver_flags(dev->dev, DPM_FLAG_NEVER_SKIP); | ^~~~~~~~~~~~~~~~~~~ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_kms.c:202:38: note: each undeclared identifier is reported only once for each function it appears in make[2]: *** [scripts/Makefile.build:290: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_kms.o] Error 1 make[2]: *** Waiting for unfinished jobs.... /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_fence.c:30:1: warning: ‘dma_fence_test_signaled_any’ defined but not used [-Wunused-function] 30 | dma_fence_test_signaled_any(struct dma_fence **fences, uint32_t count, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_reservation.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_suspend.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_workqueue.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_seq_file.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_connector.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_backlight.o /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_pci.c: In function ‘amdkcl_pci_init’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_pci.c:103:84: warning: passing argument 2 of ‘amdkcl_fp_setup’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers] 103 | _kcl_pcie_link_speed = (const unsigned char *) amdkcl_fp_setup("pcie_link_speed", _kcl_pcie_link_speed_stub); | ^~~~~~~~~~~~~~~~~~~~~~~~~ In file included from /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_pci.c:4: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_common.h:12:63: note: expected ‘void *’ but argument is of type ‘const unsigned char *’ 12 | static inline void *amdkcl_fp_setup(const char *symbol, void *fp_stup) | ~~~~~~^~~~~~~ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_update_scratch_regs’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:235:6: warning: unused variable ‘i’ [-Wunused-variable] 235 | int i; | ^ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_find_encoder’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:258:6: warning: unused variable ‘i’ [-Wunused-variable] 258 | int i; | ^ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_best_single_encoder’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:373:6: warning: unused variable ‘i’ [-Wunused-variable] 373 | int i; | ^ CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm_atomic_helper.o /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_dvi_detect’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:1121:7: warning: unused variable ‘i’ [-Wunused-variable] 1121 | int i; | ^ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_dvi_encoder’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:1177:6: warning: unused variable ‘i’ [-Wunused-variable] 1177 | int i; | ^ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_encoder_get_dp_bridge_encoder_id’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:1341:6: warning: unused variable ‘i’ [-Wunused-variable] 1341 | int i; | ^ /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c: In function ‘amdgpu_connector_encoder_is_hbr2’: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu/amdgpu_connectors.c:1366:6: warning: unused variable ‘i’ [-Wunused-variable] 1366 | int i; | ^ CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm_crtc.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm_fb.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm_modeset_lock.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_drm_modes.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/kcl_mn.o CC [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/dma-buf/dma-resv.o LD [M] /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdkcl/amdkcl.o make[1]: *** [scripts/Makefile.build:519: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/amd/amdgpu] Error 2 make: *** [Makefile:1780: /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build] Error 2 make: Leaving directory '/usr/src/linux-headers-5.8.0-7630-generic'
Yes, I have been following step 4 this whole time. I’ve been only operating from a terminal pointing to that directory.
"For now: it’s also a possibility to avoid the problematic package like:
sudo apt install libdrm-amdgpu-amdgpu1
How? That is the solution you provided for uninstalling the drivers. Without that I was not able to correctly uninstall it. As of this moment I’m not even sure I actually uninstalled it since the new error is confusing to me.
From what it looks like, if your kernel is too new, you won’t be able to build DKMS. I’ve been trying to figure out how but had no luck so far. I’m on Kubuntu 20.10 with kernel 5.8.0-29.
When I try to build I get errors mentioning “mmap_sem”. According to this post, anything newer than 5.7 (or maybe that has some patches from 5.7 applied to older kernels) there were changes that won’t allow building DKMS to complete. https://github.com/RadeonOpenCompute/ROCK-Kernel-Driver/issues/104
Tried the “renamed mmap_sem to mmap_lock” option on the source files and was able to get past the “mmap_sem” errors… and introduced a bunch of new errors. No idea how to fix them.
So until AMD releases a new amdgpu-pro build that works with newer kernels, no OpenCL for me. Or I can reinstall using Kubuntu 20.04 LTS.
You got the --no-dkms option to work? Every time I try, it still tries to build the dkms.
I just ran “./amdgpu-install --opencl=legacy,rocr --no-dkms --headless” and after some other stuff gets done I get this:
Setting up dkms (2.8.3-4) …
Setting up amdgpu-dkms (1:5.6.20.906300-1164792) …
Loading new amdgpu-5.6.20.906300-1164792 DKMS files…
Building for 5.8.0-29-generic 5.8.0-31-generic
Building for architecture x86_64
Building initial module for 5.8.0-29-generic
ERROR: Cannot create report: [Errno 17] File exists: ‘/var/crash/amdgpu-dkms.0.crash’
Error! Bad return status for module build on kernel: 5.8.0-29-generic (x86_64)
Consult /var/lib/dkms/amdgpu/5.6.20.906300-1164792/build/make.log for more information.
dpkg: error processing package amdgpu-dkms (–configure):
installed amdgpu-dkms package post-installation script subprocess returned error exit status 10
This is going to sound silly, and I’m amazed that it worked myself, but I was running into the same issue and got around it by simply removing the check for --no-dkms
in the installer script.
Open up your ./amdgpu-pro-install
script and look for the check_options
function. Change it to something like this:
function check_options() {
# if [[ "${OPTIONS[*]}" =~ "no-dkms" ]] && \
# [[ "${OPTIONS[*]}" =~ "pro" ]]; then
# echo -e "ERROR: using --no-dkms with a pro install is "`
# `"invalid.\nDid you want to run the following`
# ` instead?\namdgpu-install --no-dkms" | stderr
# exit 1
# fi
echo 'Skipping'
You can’t just remove it because it’s being called elsewhere, but apparently it’s just rejecting you based on the fact you’re running the pro installer. I don’t know DKMS well enough to say if this will cause problems down the line, so run at your own risk. But once I made that modification these instructions worked like a charm - I confirmed with both clinfo
and in Blender.
I used the 20.40 driver on PopOS 20.04, not sure how it might behave in other environments.
Edit: I’m on kernel 5.8.0-7630-generic
I know that this thread is not strictly for the case im going to lay out, but I’m writing about it here, in hope there is a possibility that this is GPU driver issue and maybe someone here can help me. This problem is really difficult to diagnose.
For some time I’m struggling with Blender randomly hanging out on me. It’s happenig during multithreaded workloads and the Blender process cannot be killed.
Here is original thread: Blender randomly hangs - what CLI debug options should be enabled for GPU issues?
Here is bugreport: https://developer.blender.org/T83939
As of now I’ve uninstalled all AMDGPU-PRO drivers and I’m running some tests to see if this can be ruled out of the equation.
UPDATE:
After uninstalling AMDGPU-PRO drivers the issue is gone.
Which driver version were you using?
I’ve been seeing similar behavior recently but no idea what the issue is. I wonder if maybe uninstalling and then reinstalling a different version would help?
EDIT: I started looking into this a bit more and I had the AMD PPA (oibaf-graphics
) still enabled from a previous installation attempt. Purging it and keeping my driver version at 20.40 seems to be helping. Here are some instructions on how to remove the PPA if you’re using that and want to see if disabling it helps: https://linuxconfig.org/amd-radeon-ubuntu-20-04-driver-installation
Hello @pzona!
I’m also using 20.40. I’ve reinstalled the drivers with the hack you posted above and everything so far it seems to be OK. Tested Blender versions 2.90, 2.91 and 2.92.
I don’t have PPA’s in sources.
Hmm not sure what the issue was then but glad it’s working!
It looks like my issue was related to the Mesa and Vulkan libraries being upgraded past the AMDGPU driver. If you’re not using the PPA (and are careful when upgrading) you should be okay
Hello.
Following your tutorial now I can’t even open Blender:
# Blender 2.83.12, Commit date: 2021-01-26 15:41, Hash ad0da4275159
# backtrace
./blender(BLI_system_backtrace+0x1d) [0x698becd]
./blender() [0xc15d22]
/lib/x86_64-linux-gnu/libc.so.6(+0x46210) [0x7f5e47436210]
./blender(free+0x7b) [0xef80eb]
/opt/amdgpu-pro/lib/x86_64-linux-gnu/libamdocl64.so(+0xb2f87) [0x7f5dec9bdf87]
/opt/amdgpu-pro/lib/x86_64-linux-gnu/libamdocl64.so(+0xb3db1) [0x7f5dec9bedb1]
/opt/amdgpu-pro/lib/x86_64-linux-gnu/libamdocl64.so(+0x7a923) [0x7f5dec985923]
/opt/amdgpu-pro/lib/x86_64-linux-gnu/libamdocl64.so(+0x83fce) [0x7f5dec98efce]
/opt/amdgpu-pro/lib/x86_64-linux-gnu/libamdocl64.so(+0x75395) [0x7f5dec980395]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x1247f) [0x7f5e47b3b47f]
/opt/amdgpu-pro/lib/x86_64-linux-gnu/libamdocl64.so(clIcdGetPlatformIDsKHR+0xad) [0x7f5dec9804bd]
/lib/x86_64-linux-gnu/libOpenCL.so(+0x4a66) [0x7f5deca45a66]
/lib/x86_64-linux-gnu/libOpenCL.so(clGetPlatformIDs+0xc3) [0x7f5deca460d3]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxrays23OpenCLDeviceDescription16GetPlatformsListERSt6vectorIP15_cl_platform_idSaIS3_EE+0x2b) [0x7f5dfa21856b]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxrays7ContextC1EPFvPKcERKNS_10PropertiesE+0x293e) [0x7f5dfa1b362e]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxcore20GetOpenCLDeviceDescsEv+0xff) [0x7f5df9bc259f]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x462c56) [0x7f5df9b79c56]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18bb045) [0x7f5dfafd2045]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18bb1a8) [0x7f5dfafd21a8]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18c1283) [0x7f5dfafd8283]
/home/administrador/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18b88f9) [0x7f5dfafcf8f9]
./blender(_PyObject_FastCallKeywords+0x104) [0x5710ef4]
./blender(_PyEval_EvalFrameDefault+0x6e42) [0xc0fdb2]
./blender() [0xc07ec0]
./blender(_PyEval_EvalFrameDefault+0x88dc) [0xc1184c]
./blender(_PyFunction_FastCallDict+0x2a6) [0x5710796]
./blender(bpy_app_generic_callback+0x18d) [0x1206c4d]
./blender(BKE_callback_exec+0x3f) [0xc1d52f]
./blender(WM_init+0x216) [0xed4e46]
./blender(main+0x293) [0xb4c6c3]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f5e474170b3]
./blender() [0xc1249c]
I am on Lubuntu 20.04.2 (5.4.0-67-generic) using driver amdgpu-pro-20.45-1188099-ubuntu-20.04 for a RX 580 GPU:
sudo clinfo
[sudo] password for administrador:
dlerror: libamdocl-orca32.so: cannot open shared object file: No such file or directory
Number of platforms 1
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.1 AMD-APP (3188.4)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Platform Host timer resolution 1ns
Platform Extensions function suffix AMD
Number of devices 1
Device Name Ellesmere
Device Vendor Advanced Micro Devices, Inc.
Device Vendor ID 0x1002
Device Version OpenCL 1.2 AMD-APP (3188.4)
Driver Version 3188.4
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Board Name (AMD) Radeon RX 580 Series
Device Topology (AMD) PCI-E, 07:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 36
SIMD per compute unit (AMD) 4
SIMD width (AMD) 16
SIMD instruction width (AMD) 1
Max clock frequency 1366MHz
Graphics IP (AMD) 8.0
Device Partition (core)
Max number of sub-devices 36
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 1024x1024x1024
Max work group size 256
Preferred work group size (AMD) 256
Max work group size (AMD) 1024
Preferred work group size multiple 64
Wavefront width (AMD) 64
Preferred / native vector sizes
char 4 / 4
short 2 / 2
int 1 / 1
long 1 / 1
half 1 / 1 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
Global memory size 8407891968 (7.83GiB)
Global free memory (AMD) 8191748 (7.812GiB)
Global memory channels (AMD) 8
Global memory banks per channel (AMD) 16
Global memory bank width (AMD) 256 bytes
Error Correction support No
Max memory allocation 6946812108 (6.47GiB)
Unified memory for Host and Device No
Minimum alignment for any data type 128 bytes
Alignment of base address 2048 bits (256 bytes)
Global Memory cache type Read/Write
Global Memory cache size 16384 (16KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 16
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 256 bytes
Pitch alignment for 2D image buffers 256 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 2048x2048x2048 pixels
Max number of read image args 128
Max number of write image args 8
Local memory type Local
Local memory size 32768 (32KiB)
Local memory syze per CU (AMD) 65536 (64KiB)
Local memory banks (AMD) 32
Max number of constant args 8
Max constant buffer size 6946812108 (6.47GiB)
Preferred constant buffer size (AMD) 16384 (16KiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Prefer user sync for interop Yes
Profiling timer resolution 1ns
Profiling timer offset since Epoch (AMD) 1614249385312070405ns (Thu Feb 25 04:36:25 2021)
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Thread trace supported (AMD) Yes
Number of async queues (AMD) 2
Max real-time compute queues (AMD) 0
Max real-time compute units (AMD) 0
SPIR versions 1.2
printf() buffer size 4194304 (4MiB)
Built-in kernels (n/a)
Device Extensions cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_khr_spir cl_khr_gl_event
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform
clCreateContext(NULL, ...) [default] No platform
clCreateContext(NULL, ...) [other] Success [AMD]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
Yes, the driver amdgpu-pro-20.40-1147287-ubuntu-18.04 worked for my operating system, although I could not install the pro variant of the driver even with the advice of pzona the standard version works fine with eevee and Luxcore, although I get a message in terminal:
/Blender/2.83.13$ ./blender
Read prefs: /home/administrador/.config/blender/2.83/config/userpref.blend
found bundled python: /media/administrador/WD-Black/Blender/2.83.13/2.83/python
BlendLuxCore 2.5beta1 registered (with pyluxcore 2.5beta1)
Updating device list
LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction
renamable $vgpr2 = V_CNDMASK_B32_e32 32768, killed $vgpr2, implicit killed $vcc, implicit $exec
LLVM failed to compile shader
radeonsi: can't compile a main shader part
Read blend: /media/administrador/WD-Black/Blender/Blends/wanderer.blend
TIFFFetchNormalTag: Warning, Incompatible type for "RichTIFFIPTC"; tag ignored.
But it seems to have no negative effects on rendering at a glance.
Thanks for the advice.
Hi, I’m not sure if this is mentioned in the guide. I have seen that some Ubuntu users needed to add the Linux “user” to video and render group when installing pro driver with legacy OpenCL (./amdgpu-pro-install --opencl=legacy --headless).
$LOGNAME is your Linux User name.
So for those who can’t get OpenCL working, just in case follow those steps to add the user to those groups.
Hey, thanks for the comment.
I preferred to omit this information because:
This guide has to cover too many marginal cases anyway and is already very bloated.
In forums are many experiences, that the Linux login can be affected.
Up to a complete rejection of the login.
However, since this information can be found instantly on a Google search, it shouldn’t be too much of a loss.
No problem. I just wanted to mention this in this thread where different tips related to ATI in Ubuntu and derived Linux distributions are being collected.
On Pop 20.10 trying to run ./amdgpu-install, I’m getting the following
PACKAGES: clinfo-amdgpu-pro opencl-orca-amdgpu-pro-icd clinfo-amdgpu-pro opencl-amdgpu-pro-icd
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait
E: Unable to locate package Name
Any idea why that would be? It’s happening with both Rev 20.20 and 20.40.
Thanks, @Tpal. My Radeons are no-pro, but I’m running them with -pro drivers anyway. After reinstall the issue is gone. I think it was related to some Mesa package.
Shame that Blender does not work with either 20.45, or recent 21.10 AMD drivers.
