Wow, those export times looks amazing!
FINALLY! Quite a few times I was embarrassed to first show people how great Blender can be and then having to show them how to import assets into Blender just to sit there in awkward silence for 5 min.
Please test the build!
Thank you @lazydodo
f01a7d508d0d is the latest hash as of now.
The exporter is in the expected place, File > export > OBJ new. It only exports the single selected object as of now. And that should be mesh only. Not curves etc.
Also, if you run blender by console, you can see the export timings too.
Let me know about the bugs! Best is to share the steps to make a problematic mesh. If sharing the file is a must, please minimise its size.
It is currently crashing for me
@EitanSomething Thanks!
Fixed. rB3cbd4516c68f89942742c175ba7cdc2ce951b2d7
is the latest hash.
rBc2fbfb421ba4 fixed the issue.
Updated build should be available about 12 hours from now.
I kicked it manually, will probably be 8-10 minutes done!
Week 2 Report: June 8 to 13
- The OBJ exporter now exports Texture Coordinates. rBf01a7d50. Not the MTL file yet. It’s a goal of Week 3.
Also see the table of comparison in #15 - Since fstream is not adding any benefits and is slower too, it was removed.
- It also exports multiple objects in the same file. But so far only
OB_MESH
object types are supported. rB40736795. - Multiple frames can also be exported now, in individual files. rB6d088bdd.
- Progress is now shown on per-file basis in Terminal and timing in the end. It should be improved to act on per-object basis when there is a single frame.
- The windows build to test is up: https://blender.community/c/graphicall/Pmbbbc/
Week 3 Todo
- Curves, Axes transform, Scale transform.
- Object Grouping, Indices (absolute is already there, will discuss about relative.)
- Materials, Triangulation.
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Weekly_Reports
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Daily_Reports#Week_2
This is awesome! Thanks for your work on this Ankit, it’s really appreciated. Obj export got 10 times faster. Still using OBJs because of zbrush and it’s not gonna change any time soon, so this speedup is going to be a huge time saver.
Hey all! More features and less memory usage this week!
Week 3 Report: June 15 to 19
- Animation: Allow all frames to be exported, instead of 0-1000. Also filenames are also edited with frame number only if there are multiple frames. rB45461012
- Worked on exposing more settings in the UI:
- triangulating a mesh, rBc3f8e955
- export UV vertices, export normals rB41f47cd8
- axes transform (up, forward axes). rB1d75ece6 Scaling factor rBd47318fb
- Add support for curves to be exported after converting them to meshes.
- Refactor the code upto now to object-oriented style. D8089
This allowed us to have minimal memory overhead with no timing cost. UV vertices, however, have to be allocated on heap and thus show a peak while exporting.
Week 4 Todo
Unfortunately, I couldn’t finish some goals at time: Material library, NURBS and grouping settings. A quick thing to add is export selected objects only.
So the goal for next week is to finish them as soon as possible and start with importer.
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Weekly_Reports#Week_3:_June_15-19
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Daily_Reports#Week_3
Great progress!
Something that’s mildly annoying is obj’s inheriting that 90 degree rotation as they import (due to Z pointing up in blender I guess) Would it be possible to apply those transforms in the background as importing/exporting? Not sure if it would mess with peoples pipelines, for rigging it can be painful at times.
Also, something that’s probably out of the scope of this project but I personally do constantly in many packages (with the use of addons/plugins mostly) is to optionally export selected meshes as separate objs based on their mesh names, or import multiple objs at the same time with the naming being based on their file names.
I know it’s not on the roadmap and probably falls under a different category as I’ve seen plans for drag and drop and automatically detect the format when importing, but I figured I’d throw it in here.
I know the difference in the axes. The python exporter rotates the object about x-axis on its default settings. The cpp one doesn’t. It exports the object the way it looks in the viewport.
I don’t know why the rotation is there. I will see what other addons do or ask someone why they do it.
It’s a very minor change though.
I will expose the “select objects only” soon. More features on top of the goal of making the cpp one drop-in replacement of the older one should be handled when I’m not at a risk of failing. (:
Drag and drop is bound to the File Browser and the way operators work. (or something to that effect as far as I remember ) I think UI (and data, assets & IO) team should add the feature and the importers will make changes in their own code to make it work.
Week 4 Report: June 22 to 29
- Cleanup and review update in the OOP refactor: rB0f383a3d.
- Support NURBS being exported in parameter form, optionally. So far, they were exported as meshes. rB31d48017.
- Support NURBS surfaces to be exported as a regular mesh. rB31d48017.
- Broke down files to create new ones for
OBJMesh
andOBJNurbs
. rB6c98925d Later on,MTLWriter
will also have its own implementation file. - Support material library export. We decided against using the existing python writer, since there were no benefits of using it except saving some time now. To extend support, one would have to edit Node Shader Utils file first. Also debugging it would be a trouble. Since nodes are already in C/C++, we have more control there, instead of in the API.
- Export of single material per object: rB827869a4. Support for multiple materials in one object: rBfaa11ec0
- New options in the UI:
- Object groups: rB90869897
- Material groups: rBbab0fce9
- Export selected objects only: rBd724bf37.
- Bug fixes:
- Duplicate texture coordinates: rBef0eff0b
- Show red colored warning if overriding an existing file while exporting (it was a wrong flag) rBc39128ca
- Fix socket vector being read as socket RGBA rB7685d9e4
Remaining tasks and Week 5 todo
- Smooth groups (and bitflags) & Vertex groups
- Start with importer. I’m already lagging here User:Ankitm/GSoC_2020_Proposal_IO_Perf#Project_Schedule. But since the refactor I had planned for week 7 (along with profiling) won’t take long, I feel that I have a good buffer to work in.
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Weekly_Reports#Week_4:_June_22-27
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Daily_Reports#Week_4
Exporter is finished now.
Week 5: June 29 - July 4
- Support smooth groups and bit flags, per face rBd85c2620 rBfe3a359f
- Support vertex groups per face rB012175f8
- Support modifier’s viewport and render properties 639d512369
- Review update to adhere to style guide & comments update. rBc2eb16f6
- Null Checks: material rB35dc587f, image rB46939815, UV map rB02fa1f0b, deform vert 5a1ecb1702.
Ticked exporter checkbox in the status tracker task. T68936
Week 6 todo
Importer!
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Weekly_Reports#Week_5:June_29-_July_4
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Daily_Reports#Week_5
Week6: July 6 - 10
- Setup clang tidy with Ninja. On macOS, had to build llvm + clang 11 + tidy to get the executable. Also setup a build with clang 11 + leak sanitiser since Xcode’s asan doesn’t provide the functionality.
- Import a mesh successfully in the viewport. And add its object in a collection. It took a long time, trying to avoid Mesh, BMesh asserts, seg-faults and memory leaks due to un-freed meshes.
– The mesh has vertex data only, so far. Texture coordinates are to be added.
– The parser takes a long time. ~70% of the import process. Making a Blender object from the parsed data is the rest ~30%. So need to optimise it.
– The importer is still 3-4 times faster than the python one.
Side note: an interesting diff is under review: Use mmap() IO for reading uncompressed .blends
Week 7 planned tasks
- Texture coordinates, normals and curves.
- Vertex Grouping, object grouping.
- Material library and grouping.
Nice!
May the force be with you!
Week 7: July 13 - 17
- Break code into mesh, objects, and reader files. rB7582bbd5
- Directly create Mesh without using intermediate BMesh ec04edfe5c. It lowered the peak memory usage by half. Also made mesh creation faster.
- Use
stoi
andstof
instead of>>
for faster parsing. aacb1f4756. Time taken in string to float conversion is less now as compared to>>
operator. But the cost is in splitting the string and allocations made for several substrings. Overall this is faster.
OBJ import the same file as last week using stoi
. cube subd 8; 23.3MB file.
- Fix UV crashes and redundant loops in v1//vn1 case. rB92be92be
- Support meshes with edges with or without polygons. 5a9b983263
- Importer: Support smooth shading for polygons. rB031c4732
- Importer: Fix misaligned UV vertices of a mesh rBfe4c5350
- Exporter: fix vertex normals not being exported when smooth shading is enabled. Calculating smooth groups before exporting normals was the solution. rB501ead4b
Week 8 planned tasks
- Due to curves, the parser needs some changes in how it stores the vertices. There can be vertices that belong to no object. And then later on an object refers to them with relative indices. So there needs to be another copy of all vertices which can be referred to by curves.
- Grouping
- MTL
Week 8 : July 20 - July 25
- Move vertex (and UV vertex) list outside
OBJRawObject
so that objects that are defined (o curvename
) after the list of vertices is written can access them using relative indices. rB71eadb4b628 - Support NURBS curve import rB6e21f8c20da. Got help from Howard Trickey for fixing a visibility bug. rBaf278ce58bc
- Fix build errors: avoid
uint
with Vector’ssize()
function. rB7bd38c27761. Style guide was updated to discourageuint
usage and{}
initialisation doesn’t allow narrowing conversions. There’s still a lot of code in OBJ exporter that usesuint
, that’s for a Friday. This commit was only for removinguint
withVector.size()
. - Conform to style guide, add documentation 97aa9d44fa0.
- Rename
exportable_meshes
toexportable_as_mesh
rB47166605915. (This was long due.) - Cleanup: silence clang-tidy warnings; comments. rBffaa1df4397.
- Move Object creation code in Mesh creation class. rB2bb56c83faa. This helps adding deform groups and materials to the
Object
in one place and away from the code that adds thatObject
to a Collection. - Support importing vertex deform groups. rB25526821a4b.
- Use VectorSet instead of vector for def_group. rBb33a4592a38. The commit rB37467ec5e9a used
std::vector<std::string>
which is slow due to linear searching. Jacques Lucke suggested usingVectorSet
for faster lookups. AlsoStringRef
is used to avoid copying. - Wrote an intial draft of importer’s design document. T68936#982751. Still need to incorporate mentors’ feedback on the document.
Next Week plans
- Fix design doc.
- MTL and material grouping.
- Port a portion of mesh editing tools written in python to C++:
bpy_utils.mesh.ngon_tessellate
(inrelease/scripts/modules/bpy_extras/mesh_utils.py
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Weekly_Reports#Week_8:July_20-_25
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Daily_Reports#Week_8
Bro, will you support loading files by drag and drop?
Sadly, not in this project. It is not specific to the three formats mentioned here.
Week 9 July 27 - 31
- Updated design doc: https://docs.google.com/document/d/17Uzl47OljjoKgaMbukiLHUVGQP220lPTmPS-atb65mw/edit
- Add fallback value in string to number conversions. rBc5bd1631
- Add MTL parser. rB19145856
- Cleanup: Use MutableSpan, add asserts & make exporter’s material code similar to importer’s. 48d3582196
- Initial material creation support. rBc401d8a0
I could not work for the whole week productively.
- Off-topic (Master) Enable header auto-complete suggestions in Xcode. rB27d50d6f This turned into a standardised way of dealing with Xcode’s include file paths.
- Off-topic: Respond to a new developer on a bug fix and the devtalk thread
- Off-topic: Tested ClangBuildAnalyzer on Blender (lite build).
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Weekly_Reports#Week_9_July_27_-_31
https://wiki.blender.org/wiki/User:Ankitm/GSoC_2020_Daily_Reports#Week_9
Delayed the weekly report by a day since yesterday was a holiday in India.
