Hi!
Curves supports bevel modifier, but it do nothing. Is that a bug or it is supposed to do nothing?..
I believe it should bevel vertices, it is very helpful for creating pipes.
Or, if it is not possible for curves then bevel vertices of mesh made of edges only.
That’s my main desire for the Bevel modifier, for it to be able to go beyond surrounding geometry in a practical way. Excited to hear you’re starting to look at this!
DotBow - the bevel modifier has no effect on Curves, sorry. You would have to convert it to mesh.
For a mesh that has no faces (just edges), use the ‘Vertex only’ flag of bevel. Ordinary bevel (without that flag set) is only intended to bevel edges that have exactly two adjacent faces.
cgslav: I have looked at Ilya’s code in the bevel-after-boolean, and indeed it has some good ideas, using some existing tools in Blender chained together. It would be nice to change bevel to be able to do this for arbitrary sets of selected edges, not just those that come from intersections during boolean operations. But that case is harder because in the general case there can be more than two edges beveled at a vertex. Eventually Ilya and I should collaborate, I agree, but as I said above there are other things in my TODO list with higher priority right now.
Hmm, for some reason I didn’t enable vertex-only bevel for wire edges (those without faces) in the modifier. I think because I only added it the tool later and forgot about the modifier.
For now, you can use the tool (control-shift-B).
I’ll fix the modifier for 2.8.
Hi there @Howard_Trickey , I appreciate the hard work you are doing on Blender!
Concerning the Bevel topic I was wondering if there will be a QUAD Chamfer/bevel improvement for insets and extrusions. Currently they give an un-desired shading effect not suitable for Game Art normal maps.
Currently there is a workaround using MESHMachine script but its only a band-aid fix and destructive in nature (have to collapse the bevel modifier first).
I can’t predict when, but yes, there will be such an improvement in the built-in bevel with respect to toplogy oprions at vertices. This is now clearly the top requested feature, or maybe it is tied with having bevel “dp the right thing” when overlap occurs (but that’s rather harder to fix, in the general case). I am aware of the various addons that do some of this and will use them for inspiration, but would like to come up with solutions that work in the general case, and pay attention to the hard-to-get right things like what happens to the UV maps, edge data, etc.
If you take a look at this video, it shows a sphere with a chunk booleaned out. The mesh has hard edges where the boolean subtracted and has custom normals to fix shading issues as a result of triangles, ngons and uneven polygon density.
The problem is, the bevel modifier will mess up the custom normals. The only fix right now is to apply the bevel and fix the normals again manualy, on the mesh level.
And so I was wondering if it would be possible for the Bevel mod to use the existing custom normals, if there are any. This would be a live saver and add a lot of flexibility.
This, would be amazing for gamedev creation. 50% of my projects nowdays rely on weighted normals (then just normal decals) and being able to keep bevel modifier and still be able to tweak weighted normals would be amazing. Preferably with a value of 1-100 (like the 2.8 normal weight modifier). Or a simpler version like the y.a.v.n.e pluggin where its just a weak/medium/strong value.
There is no reason for that. You don’t want anything less than 100% of the previous, custom defined normals. It’s not about weighting face areas to influence the normal generation, just take the existing ones and set the normals at the bevel periphery accordingly.
im not sure it has been mentioned but the bevel behaves a little odd with the mirror.
In 2.79 you could mirror and also bevel in a stack. with mirror first.
In 2.8 it has a stack order issue. If the mirror is first (which helps further booleans connect) there is an issue with the bevel showing up on weight.
I love all the suggestions here so far. If any of these get added the modelling would be light years ahead.
Thanks, mx2. It seems that the mirror modifier in 2.8 does not properly propagate edge bevel weights. There was a big change internally for modifiers, getting rid of the concept of “derived mesh”, and I suspect that that is the reason for this oversight. I hope I can find time to look into this.
Hello, I have always wondered, is it possible to add a “Smart Clamp” check box? So rather than allowing one overlapping vert from stopping the entire bevel, it would instead detect and clamp only that one individual vert, so that way the bevel width can continue while preserving a clean mesh. I’m sure it would be expensive on the CPU when more and more overlapping verts add up, but that would still be something I think generally everyone would find worth the wait.
