The fulll of joy ! can you show us some image results
I agree, it would be great to collect profiles for presets. And I think presets would really make the feature so much more useful! Ideally we could do this after the drawing widget is working better, because it’s a little frustrating to edit curves right now.
Could it be possible to not have a bevel on the edge when we come on the line?
Unwanted result
Wanted result
Tell me if it’s possible, please
A video for explanations.
oh man, it would be so cool and would put behind so much headache with those issues!
I’m getting back to basics here. Could anyone give me a reason why there has always been this issue with beveling sharp corners (oblique angles) in blender? The only workaround to the non-round looking bevels that occur with sharp corners is to change the profile amount to something between 0.35 and 0.45 but is a bit annoying because it means I have to bevel the sharp corners separately.
The circles are for reference, and they show what to me an ideal bevel would look like.
This is a choice I made at the beginning about how to handle bevels between faces that do not meet at 90 degrees. The way Blender does this is to always make a profile that is a quarter of a circle (or quarter of a superellipse, if the profile parameter is not 0.5). Then if the faces don’t meet at a 90 degree angle, a transformation is applied that takes the 90 degree angle into the actual angle. This gives the effect you note in your diagram.
The alternative you show looks easy but is actually not so easy. What you are doing is inscribing a circle in the angle and noting where the circle is tangent to the two enclosing edges, and then using an arc that is that percentage of a circle rather than a quarter circle. The problem is: what if the tangent points don’t match where the bevel wdith parameter says they should be? With circular profile and a non-percentage width type, it will work out ok. Admittedly this is a very common case, but what to do in other cases?
I suppose we could add an option to try that way. Do other users feel this is an important option to have?
With this option bevel would definitely be much closer to some common real world use cases, like using router bits of a certain size or rounding edges of different shapes to the same radius.
I’ve actually run into a similar situation a few times before and I didn’t even think to try with the bevel tool!
The trouble seems to be with each new option it makes all the other options harder to access for people who aren’t familiar with the tool.
I wonder if there could be presets for the bevel operator options, that would be pretty cool!
Thanks for the reply. I’m gonna have to read it multiple times to fully understand, but I think I vaguely follow and see there’s a complication. What if there could be just an automatic adjustment of the Profile value that we already have? The automatic adjustment would work based on the angle of each corner and would try to simulate the perfect circle-based fillet. For example, with a 90 degree corner the Bevel profile would be 0.5, but if a corner is 45 degrees, a 0.4 profile is applied to that corner, and a 0.35 profile is applied to a 25 degree corner etc. Something like that.
Granted, I am not thinking through all possible cases. I’m actually only thinking through the 2d situation I showed in the diagram.
I wonder if a combination of the super-ellipse function combined with the transformation to the original angle can actually form a perfect circle. After playing with it for a minute it looks close, but I couldn’t get it to match perfectly. There’s also the problem of the profile’s edges being smaller in the middle of the profile.
It would be cool if that worked though! Definitely simpler to implement that way.
Yes, please. That “inscribing a circle” method should be able to produce nice looking result.
If I understand correctly, in such method bevel should be limited by tangent points of inscribed circle with specific radius, and maintain a curvature of such circle for any angle.
very important.
Absolutely all products in the real world use exactly this chamfer method. Because technical drafting and engineering design use this to create these products that surround us.
I would expect default bevels at 0.5 to always match a circle arc as close as possible at all times, as other users mentioned that is what most real world bevels would look like.
However I understand the technical limitations, and that it may not always be possible.
When I use bevel on edge between two materials Have some problems with material assign. If we can add perfect assign material on bevel arc / patch mode its be so good.
Yeah, there’s an open bug about material assignment. The problem is, the code has to “break the tie” as to which material should win when there is an odd number of segments. The current method for breaking the tie is not good. A suggestion has been made to break the tie by using material slot #. That seems like a better idea, and I should do that.
I’d honestly might prefer if these weren’t implemented to ‘bevel’
First one is bevel+extrude or inset+transform. Second one is is the same with added profiled loop cut.
If you start adding stuff like this to bevel I think it is easy for tool to become very convoluted.
I guess philosophically speaking it wouldn’t be different from before since all the basic operators already are basically multiple operations in a macro but… somehow I feel like this goes beyond ‘bevel’
Certainly as features these would be nice to have but maybe as compound tools instead. Albeit with Everything Nodes™ it might become redundant sooner than expected if it becomes easy to take operation, procedural select its result and apply more operators.
It’s really hard to draw the line, but I’d tend to agree with you - in the example shown, there’s what we might consider creation of volume, whereas bevel - in its real-world variant at least, which after all is what Blender’s tool is based on, is pretty much only substractive and operates on an already existing ‘protrusion’ or ‘extrusion’ so to speak. Now this is not to enter a philosophical debate but to decide where to draw the line between different operations.
You can already do that, select a face, and press ctrl + b, the only different is instead doing an extrude, it is actually beveling the surrounding edge
Nope, it’s not the same thing, hence my request.
I asked for it in the bevel profiles thread, idk about coding but from a conceptual viewpoint is much easier for doing any profile shape https://www.youtube.com/watch?v=1jnr-vWzSDo
