Please don’t take me wrong you know I only want the best for this, I’m amazed with what you are doing here and I just want to understand
Thanks! I suspected that but I wanted a confirmation from you to understand where are we heading, this is going to be awesome
Keep in mind that we were talking about a simple operation, if we consider complex operations, like a custom physics solver made with function nodes, there we could expect a much slower performance, hence I’m not worried about that specific situation but a more production realistic situation with much more complex functions.
Also we don’t use 2 billion, but we need around 100 million particles to properly simulate a small square of deep sand, so being able to handle quite a few millions is very important, the same goes with water foam, to have proper foam we need a few millions.
And anyways the idea is to have the maximum possible performance to avoid having to create custom code that has to be compiled within Blender to generate custom solvers for example, this will simplify part of the Fracture Modifier implementation
Reading the document, I’ve got the impression that the functions will be saved in the blend file…
Would it be possible to extract them from the blend file so that we can make independent libraries of functions? I’m just thinking that the users may want to re-use their functions in other projects or share them. Functions could have their own file format. One function or multiple functions could be contained in one file to form a module as in python.
That might be related to the asset manager; cause you could also want to make an external library of animations, with one file per animation, or bundles of animations…
I would assume that it would work like any other blender data. IE shaders- if a user creates a super cool shader and want to reuse it, they save it to a blend file and append it in any other scene that needs it.
@Nodragem Node trees that define functions will be stored in the .blend file and can be linked/appended to other .blend files. However, it is unlikely that you will be able to use those functions outside of Blender. At least in the current design.
@Random There is a switch node that selects one of two inputs based on some condition. Currently, this case is not optimized (so both inputs will always be evaluated). I’m aware of two different optimizations I can implement later.
I did a mock-up for a proposed iterative node group over on Right Click Select – this is for material nodes, but it might offer some insight into how to design the UI.
It’s not quite clear if the proposed system can extend (or replace?) existing shader node system.
Seems like it’s totally impossible without rewriting half of blender core and cycles.
I would love to see the ability to have node-trees interact with unlike types of node-trees. For example, maybe in the future, if there are rigging nodes we’d want them to have access to everything, for the purpose of control. This is one of the few features I really like about Maya-- being able to connect any two nodes in a variety of ways.
@jacqueslucke Did you ever make a mockup of how loops could look for Animation Nodes? Have any feedback about the mockup I made?
I’m not perfectly sure, but I think that loops (of non-static length) require some state in one form or another. And the state is not expressable in stateless dataflow. It’s just on another level of computational complexity. Combined with ‘switch’ node it becomes possible to implement full FSM.
There are no loops in Maya, and simulations are run inside black boxes (one single big node). Houdini has a special kind of node called solver in which you can dive and access previous frame information, bit I haven’t used it a lot, I couldn’t elaborate.
Your proposal is missing a lot of details that are important. For example, how does the loop know which nodes represent the iteration rule? Is it all based on names of nodes and frames?
Furthermore, loops add a lot of complexity to a node system and I’m not sure if it is worth it to add this functionality to Cycles nodes. Loops with an undetermined iteration count could also make it much harder to run them on the GPU. Lastly, this topic is not about Cycles nodes, so let’s stay on topic, please.
The idea I had was that there would be new node-types that are similar to node groups - the iteration rule would be a group with the current iteration as a single input, and the result of the iteration rule as an output. The Current iteration would be a group, too, taking the iteration and any constant parameters as an input. Then the combination rule would also be a group that is optional, for combining the results of various iterations. I think this UI might be approachable in any node-tree, but of course it still needs some work.
I wasn’t trying to go off topic-- of course this isn’t the place to talk about Cycles! I just wanted to offer a UI suggestion, although it looks like you’ve already put quite some thought into this! Thanks
As for this comment:
I was just thinking of a far away future, after Modelling and Particle Nodes are already implemented.
I can’t find anything related to instancing objects to particle positions/rotations, except at milestone 2
(Use cases are supported (particle scattering, weathering, …).)
Will we have instancing of objects at the earliest at milestone 2, or will basic instancing be implemented in milestone 1 already.
I’m wondering because I think the Functions system is already pretty capable to be used for a lot of motion graphics stuff, we would normally do in animation nodes. When it is not to much work to implement, groups for manipulating instances could be build and tested already.
So when milestone 2 would be active, there could be already a lot of group nodes ready for shipping with blender or at least some tests could be made in advance. Personally I would love to rebuild the feature set of c4d mograph effectors and it’s cloners, also to learn how these systems work
Anyway, do you have already plans or technical details on how such instancing could be implemented in a good performant way? Will there be a new type of system which draws the instances nested, or will they be shown in the outliner, like it is with animation nodes at the moment? (Which would be not that good of a performance I quess.)
Please ignore if you already answered this questions ^^
Pretty late to the party here, but I would like to add that Houdini has a “For each” node. Actually there are 6 of them:
-For Each Connected Piece
-For Each Named Primitive
-For Each Number
-For Each Point
-For Each Primitive
-For Loop with Feedback
Having a sort of language like vex one could use along with nodes would be very nice indeed… And I find the loop interface very well thought, it’s completely clear what it does and where it starts and ends. All very good examples.
