For crush bug reports, these 2 log can help ? and hope to know the log meaning
I am currently can not edit my scenes with blender 2.8 builds and eeVee
Because blender 2.8 usually crush. it just happen, when I change property editor to" material"
or change render mode to EeVee or, change material to dev-mode.
I want to edit materials for Eevee (which made for cycles) of the Figure, to render with Eevee .
then I removed most of obj, at current there are only 2 meshes (figure + hair) only. but same crush
still happen. I often save the scene,but it seems not work for these frequent crushes.
Then I try debug mode, with power shell, so I get these 2 logs. untill blender crush for the scene.
Pass : Depth Pass Clip, Uniform ‘ba2837647274’ not found!
Pass : Depth Pass, Uniform ‘ba2837647274’ not found!
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF6FCAE8C80
Module : C:\myprograms\blender-git\build_windows_Release_x64_vc15_Release\bin\Release\blender.exe
The Depth Pass Clip record are long, there are same record untill load finish the scene.
and when blender crush, I must see, this EXCEPTION_ACCESS_VIOLATION about same Address.
Is it blender bug, or my PC side?
These kinds of issues you should report to the bug tracker, with all the information required including system information and steps to redo the problem.
Yes of course I plan to report. but I can not confirm it if my pc side or code problem, then asked here first
to get some hints.
And developer may hope to test samething, but I can not attach blend.file, because mesh and textures include products. so I hope to know clear, which infomation may useful to report. (I understand must need to
attach system infomation)
