File save bug
I found an error in Blender, when I tried to save a file I accidentally saved a file without a name, I think I pressed a key by accident and the result was that my project was saved with the same name as the directory, in this case I always save on the desktop, but the problem was that it saved with the same name and no file extension, and when I noticed the icons on my desktop disappeared and errors appeared saying that the path to Desktop was not found, then I used some commands on the desktop. cmd and I could see that it saved the project as Desktop and renamed the original Desktop as Desktop1, I had to rename the Desktop to Desktop2 and return to the original, then I restarted and it was back to normal, but that being said, I just wanted to report this problem, not that it’s really a problem but it should be resolved as soon as possible, thank you!
please use the report a bug link near the top of the screen
