Hi there!
I was wondering is there any chance to see this features in next blender releases:
In compositing sidebar a button that creates file output node with inputs based on render layers. And also some settings for this button:
- you can select the number of inputs per render layer
- ability to name suffixes for every input
- a checkbox that makes this button create file output nodes per render layer instead one. Number of inputs per render layer still remain.
An example:
I have 2 render layers:
- Cube
- Sphere
I want to export combined, diffuse and ao passes per each render layer. I am navigating compositor sidebar to change some settings:
Selecting “3 inputs per render layer”. Then 3 entry fields appear. I leave first one blank, in second typing “_diffuse”, in third typing “_AO”. Then i hit this new button and it creates file output node with 6 inputs:
- Cube
- Cube_diffuse
- Cube_AO
- Sphere
- Sphere_diffuse
- Sphere_AO
If i enable this checkbox i described earlier, I’ll receive this:
First file output node:
- Cube
- Cube_diffuse
- Cube_AO
Second file output node: - Sphere
- Sphere_diffuse
- Sphere_AO
This options would be huge time saver for me. Also file output node needs one more option: checkbox that exclude frame numbers in base path.
So what do you think?
