As @BD3D said too, @jacqueslucke explained that “local” attributes (in the sense of visibility scope) are basically implemented via anonymous attributes, at least that’s how I interpreted his answer to my proposal. And that makes sense to me.
Maybe we will try the fields as they are now in the final release and we all realize that not having named attributes isn’t a big deal after all…
…or the opposite, a lot of people will come up with very valid arguments and concrete, real world examples of why the absence of named attributes is a serious functionality lack… in the latter case, I hope that named attributes can be implemented in the next 3.1 as an upgrade to fields…
maybe leave this possiblity open for 3.X series could be a decent tradeoff? I mean not implementing named attributes for 3.0 yet but design a minimal Plan B to add them in 3.X series if “things go wrong”…
(I don’t know in terms of project management how feasible is this)
there’s still time for 3.0 release for get/set nodes
time is not a problem here
the nodes are ready and we’re already implemented for the prototype, there’s tasks waiting to be pushed
I would argue for changing the build process so every RNA property becomes a named attribute by default. Of course that would need to be done carefully to avoid name collisions and maybe some properties need to be hidden for technical reasons. But basically if it is accessible as a property via python it should be a named attribute. There have been many times when I’ve hit a bug in other software that I could work around because the attributes causing the problem can be named and changed even if they aren’t exposed in the interface. It makes zero sense to me to keep most of the attributes out of reach – the whole power of attributes is to let you change the data however you need to so you can work around limits in the interface. It’s not the devs job to protect users from themselves – power users can manage the attributes as they need. Without named attributes, GN is just a toy
Do not agree.
Recently I tried to make a particle simulation with remeshing modifier on top of it. While this technic works fine in general it does not produce any motion blur, cause this attribute isn’t taken into account in the Remesh modifier.
As a way around I tried to sample the particle’s velocity attribute in the geometry nodes and store this attribute in vertex color.
Mh … please do not be that selective if you cite JaquesLucke.
A node group created by someone else uses named attributes and is accidentally overwriting your attribute. In that specific case, the node group should just have used anonymous attributes internally. If it wanted to expose an attribute to you, it should have allowed you to choose the name.
So, generally speaking, when you build a node group that others should be able to use without worrying about attribute name collisions, then you should not use named attributes inside the node group.
As far as I understand, the main problem is that groups would make/access a named attribute globally. If there is some kind of namespace for each group/modifier, there would be no danger that a named attribute could overwrite something which shares the same name.
In a studio setup with many people working and sharing data, there would be no way to guarantee that Blender would work reliably, when a ‘global’ attribute name clash could cause problems, which cannot be predicted and are hard to track down.
I guess, at the heart of the shareability issue of named attributes (means, nesting groups and chaining modifiers could work reliably) are groups which try to write/access “global” attribute names.
Groups do need to act like a scope for “local” attribute names. With group based attribute scoping, groups which use named attributes would be shareable.
Before people all around the world tweak global attributes from within groups, it does make sense that groups do get scoping for named attributes first.
best would be that they debate with us, unfortunately that’s not their job
Why are you making the point that using globals is bad?
We all agree very clearly on this, what is debated is removing globals entirely.
Globals were a very important part of geometry nodes, same in Houdini, removing them from nodetrees entirely like this with no compromise is not reasonable.
what dalai is proposing is the equivalemnt of throwing a baby with the bathwater.
i like my baby
don’t throw it away please
if you don’t like my baby just don’t look at it and ignore
During the 2.93 era, share-ability was fine because everyone used attribute remove when applicable in a group. I would like to know what problem there is now that wasn’t there before. Are they afraid that everyone will suddenly get messy because of fields?
some users not being smart when making their nodegroups
that’s seem to be the real problem? devs are trying to create padded walls to protect beginners?
also that’s a very bad practice in general
best to use locals variable to do this
they didn’t exists back in the days
still, having locals do not mean removing globals entirely…
Its not globals per se, but when globals are used in a way which destroys modularity.
Scoping means, to have a protection layer. local variables are defined inside that layer. With something like group based attribute scoping, there won’t be a name clash of named attributes across groups/modifiers, and there would not be sharing issues.
i agree that they can be problematic, but, again, removing them entirely like it’s no big deal is not reasonable thinking
look at python, we can read/write globals from the scope of a function too.
this is not a problem from python creator, if it cause a problem, that’s user fault.
the language shouldn’t impose users how to behave, if they do the mistake of using globals in a case where it was not necessary and it is causing issue, that’s their problem, they should have read the documentation!
Note that the name clash is still a problem, this proposal is not fixing any name clash, because globals can still be written as group output.
Python scopes work. A Python-user could access globals, but it is optional. He could use local variables happily without touching globals.
Blender groups lack scopes. There is no choice to make named attributes local. They are globals per se.
The idea is; proper scopes for Blender node groups could enable local attributes.
Ehm, are you sure?
There is a baby flyyyying out of the bath.
Clashes between groups and modifiers would be fixed. Thats the discussion on shareability about. The user does not need to know if the GN modifier designer uses an attribute name used by another modifier.
problem is still here
shade_smooth is “clashed”
and that’s not even a bad thing, it let user interact with builtin attributes
field prorotype way let users interact with builtin attributes more freely
right now it’s feels like a prison
we need to follow the line maked on the ground for us
field prototype way is freedom
new way is full of restriction
You actually show an example how an end user could use a modifier to write to a ‘global’ attribute. Could you explain me, how does your example has an impact shareability of modifiers in general?
You actually show an example how an end user could use a modifier to write to a global variable
well first of all it’s not really a global it’s a return value written in global space if outputted by a modifier
the get/set nodes are the ability to create/write global from function’s scope
i don’t get your second Q
Just to note, named attributes are still used to great effect by way of the group input (in attribute mode) as well as the group output (which is always an attribute field. Fields in general are great for those who expected Geometry Nodes to be like a ‘Cycles’ for geometry, it is a lot more straightforward from an artists’ perspective.
However, I do understand the obvious utility of having dedicated get/set nodes that manipulate attributes without exposing them to the modifier UI (as a feature for power users who know how to handle such a thing in a controlled manner). Perhaps they could be under a menu entry labeled ‘advanced’ or ‘low level’ to emphasize their trickier nature, much like what we already have with various other features that are not recommended for a new user’s learning project.
