By typing python code This node is for advanced users who know a bit of python.
if you’d like some tips, enable the developper tooltip, you will see the api of properties when hovering them.
This is a very demanded feature, that was removed for controversial reasons during the port of the field prototype to the actual final implementation, please check this topic Named Attribute Nodes in Blender 3.0
after using Geometry Node of 3.0 extensively, I can’t agree more with my past statement about the removal. The new named attributes access is just so awkward to work with, it is also very inconvenient for studios trying to establish their own pipeline
Can the Object Info node act as both of your object & collection nodes? It is necessary to have both of these nodes you made? Image input node seems good to me though.
No they are two separate node,
i am still working on the patch, it seems to work except very specific issues, i will have time later this month to sumbit the patch
When I scrub the timeline, the subdivision level decreases, but when I let go, the subdivision resets. This lets animators get a good preview of the animation and a good preview of the model quickly without changing settings rapidly. Geometry Nodes + a little Python is the future of rigging!
sadly, from what i heard custom node groups python api are still broken in 3.0 I do not have a lot of time to check for the issue recently, but i perhaps forgot to add ‘UNDO’ support in the operator class somewhere
Hello BD3D, I am super excited about your “Sequencer Volume” node. I tried using it and I ran into a slight issue that you probably know the solution to.
In your video, when you play the sound in the ‘video sequencer editor’, the volume on the top right under ‘sound’ changes.
When I play a sound, that volume number remains static, working like a volume on say a YT video.
Is there a simple option somewhere to change how that works, or is it because I havent installed your add on correctly.
Second question, I would be interested in a similar Node for the Shader Editor too. Does that exist, and if not would that be something that would be easy to duplicate from this Node?
I was trying to figure out a way to deform custom normals (taken from static-baked VCol, due to not being supported yet), which seems relatively futile, probably due to lack of experience in vector math.
But would it be feasible to attempt adding Custom Normal field node with slightly above beginner Python knowledge? Can mesh.loops be within python scope if executed from nodes?
Firstly, great job working on these custom Geometry Nodes! Not only do I see they are helpful, but your code has helped me to create my own custom GeoNodes too. So thank you!
As mentioned, I’ve been using this/your approach to create custom nodes. However, I have an issue with my custom nodes I feel you may be able to help me with. I know this is not exactly the correct way to approach you about such matters, but I wasn’t sure of how else to do it. If there is a more appropriate platform/forum, please let me know.
Simply:
I have NodeGroupA, which has its “update” method triggered by the “bpy.app.handlers.frame_change_pre” event handler. This works fine.
I have NodeGroupB, which contains an instance of NodeGroupA (created via “ng.nodes.new(“ID_NAME”)”). It seems as though the instance of NodeGroupA within NodeGroupB is not receiving the call to its “update” function.
Any ideas? Is there a better way to reach out to you in order to discuss and share some example code?
How do you send your update signal?
I would suggest:
for ng in bpy.data.node_groups:
if ng.startswith("NodeGroupA"): #so you also support dupplicates
ng.my_update_function()
I think centralizing “how to make custom node groups info” here is fine
But one thing is certain it’s all smoke and mirror compared to a proper C++ implementation
I’ve opened a thread named “How To Extend: GeometryNodeCustomGroup”. Hopefully, there, we can talk a little more about the details.
I should provide some code to demonstrate my predicament, I know, but I’ve not had time to allow myself to do that yet. I imagine within the next day or two I can.
The “ng.startswith(“NodeGroupA”)” is a very good idea! However, I feel I may need to review a more elaborate demo in order to fully comprehend your idea. I feel I get it, I don’t have time right now to test, but it feels very good!
