I try to patch still - it’s now 5 month I patch.
Code before was:
context.scene.objects.active = ob
obSelect = ob.select
ob.select = True
No more working. So I replace:
bpy.context.view_layer.objects.active = ob
obSelect = ob.select_get(view_layer = None)
ob.select_set(True)
But give error: Object “Cube” not in View Layer “RenderLayer”!
EDIT: I try to save object select state and make it active. I iterate thoough ob list to modify every object so I need to make select true. But after I want to give object back it select state it has before.
Please how to fix?
