HI! Will the transparency in Eevee be better than now?
At the moment we can’t see the back faces of an object when activating Transmission and Screen Space Refraction. And we can’t see transparent objects through a trasparent object (for Transparent I mean obects with the Principled BSDF Transmission set to 1.000).
Are you still working on this?
Thank you, Beniamino
EEVEE is planned to continue improving over time, likely in this area as well, though I don’t know if there are plans to tackle this in the short term. Transmission and transparency is always challenging in realtime rendering.
Ok, I understand. Thank you for your fast answer!
