Hi everyone,
the following script allows to match the children visibility of the children from their parent’s.
It creates a driver that can also be copy pasted;
I would like to use this driver without having to run the script when I open a file.
Is there a way to do so?
import bpy
from bpy.app import driver_namespace as dns
def test(self, dg):
vl = dg.view_layer
return not self.parent.original.visible_get(view_layer=vl)
dns["test"] = test
context = bpy.context
scene = context.scene
#parented objects
parented = [o for o in scene.objects if o.parent]
for o in parented:
#o.animation_data_clear() # testing
#continue
o.animation_data_create()
fcurve = o.driver_add("hide_viewport")
driver = fcurve.driver
driver.expression = "test(self, depsgraph)"
driver.use_self = True
# dummy var to make driver update.
var = driver.variables.new()
var.name = "dummy" # frame
var.targets[0].id_type = 'SCENE'
var.targets[0].id = scene
var.targets[0].data_path = "frame_current"
