why I build the cycles master branch in ubuntu will stop with error at last step ?
anybody the same?
[ 99%] Linking CXX shared library hdCycles.so
/usr/bin/ld: cannot find -lX11
collect2: error: ld returned 1 exit status
make[3]: *** [src/hydra/CMakeFiles/hdCycles.dir/build.make:283: src/hydra/hdCycles.so] Error 1
make[3]: Leaving directory '/project/cycles/build'
make[2]: *** [CMakeFiles/Makefile2:847: src/hydra/CMakeFiles/hdCycles.dir/all] Error 2
make[2]: *** Waiting for unfinished jobs....
make[3]: *** [src/app/CMakeFiles/cycles.dir/build.make:485: bin/cycles] Error 1
make[2]: *** [CMakeFiles/Makefile2:513: src/app/CMakeFiles/cycles.dir/all] Error 2
make[2]: Leaving directory '/project/cycles/build'
make[1]: *** [Makefile:130: all] Error 2
make[1]: Leaving directory '/project/cycles/build'
make: *** [GNUmakefile:35: release] Error 2
brecht
November 8, 2022, 5:58pm
2
Try apt install libx11-dev
, there is a dependency on X11 because of USD.
thank you, brecht ! and I am fresh in this project , do you recommend using cycles project do some render task in server side ? or just use blender main project ?
brecht
November 9, 2022, 8:45am
4
Either is possible, using Blender is generally going to be easier since it comes with a Python API and all the Blender functionality to import or create scenes.
thanks for your advice, lead me to the right way to going on ~
amos_lo
November 11, 2022, 3:45pm
6
thank you, brecht ! I try your cmd and success build.
use the cmd next and success render a monkey img !
./cycles --samples 10 --output ./image01.png ../examples/scene_monkey.xml
I wonder , does it support usd file rendering ? like bellow
./cycles --samples 100 --output ./image02.png ../examples/ufo.usdc
and it work ! the usdc file export from blender
