I don’t have final confirmation from the driver team (I’ve been asking) but it will hopefully be fixed in rocm 5.3.
However I do have to pedantically mention that only RDNA2 cards are “officially supported” from the AMD driver side (again something I don’t have direct control over). But of course we, the group enabling Blender support, are doing our best to enable Vega and RDNA.
Thank you very much! So maybe around September/ October if all goes well then?
Also, to make this clear, I very much appreciate your work and commitment, and I wish the ROCm team was as committed and had a lot more resources - they clearly need them. That’s just me rambling though.
If your Linux OS enables journalctl you can run the following command to check the systemd for errors on the last boot (-b-1) with human readable times (-k) sudo journalctl -k -b-1
The error should be near the bottom (use page down), in my case blender normally produces something like this when it crashes the GPU.
kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -2!
kernel: [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, signaled seq=145976, emitted seq=145978
kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process blender pid 9433 thread blender:cs0 pid 9467
In my case google reveals a widespread issue with no clear resolution, it could be blender or mesa/drm or the hardware. Hopefully you will have a more specific error.
So I have a new install of Ubuntu 22.04 and amdgpu-install_22.20.50200-1_all.deb (I wiped the hd and started over.) Both blender-3.3.0-beta+v33.c49717a82473-linux.x86_64-release and blender-3.4.0-alpha+master.a98102e32eca-linux.x86_64-release give the following response when using --debug-cycles:
I
There is good news, E-cycles/K-cycles support hip now, here is a simple rendering speed comparison.
gpu:6800xt
cycles:32s
ecycles:17s (The results are visually different from the cycles results)
kcycles:22s
The AMD HIP feedback thread probably isn’t the best place to make performance comparisons between Cycles, E-Cycles, and K-Cycles. It’s probably best you make those posts else where.
I assume you used one of the E-Cycles performance presets? Or it was automatically applied by accident?
I just thought I would explain what the differences appear to be to me.
The number of light bounces appears to be reduced or the “fast GI approximation” setting has been turned on with a low number of bounces. In some scenes this will have a small impact, in others it’s noticeable.
The scrambling distance multiplier has been decreased too much for this sample count and is introducing artifacts. It should be noted that a decreased scrambling distance multiplier typically results in an increase in performance when rendering on the GPU.
Out of curiosity I checked how HIP on Linux looks on OpenData, and either OpenData have some issues, or Radeon PRO W6800 had massive performance regression between 3.1 and 3.2.
On the surface this looks like Windows-Linux thing, but there is one Windows benchmark from 3.2 with the same regression as Linux.
I mentioned a few posts above that im using an RX6800XT
I can confirm that the UI locks up for me too in the case you describe in the viewport with two blender instances, but what happened for me earlier was in a single instance. Not only that, but but it wasn’t just Blender’s UI that locked up - it was the whole OS, rendering the PC unusable without a hard reset. It doesn’t happen with every file, just the heavier ones from the examples collection on the blender website.
I use a 6800. Thanks for raising the bug report hopefully it gets resolved. However you will probably have to work out if its Blender or amd/mesa/drm causing the fault then produce a patch that resolves the issue then get in the ear of a developer to have it merged. good luck!
Was able to to get hip working with blender-3.4.0-alpha+master.a98102e32eca-linux.x86_64-release by following the instructions here. Getting some crashes in the shader editor at the moment:
Memory access fault by GPU node-1 (Agent handle: 0x7fd6f8b7f700) on address 0x41700000. Reason: Page not present or supervisor privilege.
Otherwise has worked pretty well over the last few days.
I’m not sure how you came to this conclusion, a problem in the AMD compiler or driver seems much more likely. The same Cycles kernel code works for other architectures. Just because some other HIP applications work doesn’t mean there are no bugs in the driver.
The Blender dev team has many, many things on their plate and they need to prioritize what do they do with their available time. Right now, with the available manpower they haven’t being able to enable polaris because that’d mean figuring out, writing and debugging a new device.
I’m sure they want to support as much card as possible, specially old ones, since that enables them to fulfill/comply with Blender’s vision that
“Everyone should be free to create 3D CG content, with free technical and creative production means and free access to markets.”
But truth is they can’t right now. But, probably, if there’s some community provided solution, they might include it (I can’t speak for them, but I suppose that).
It would appear AMD’s HIP implementation didn’t meet expectations and they lost user share compared to the old OpenCL implementation. I think the following items have contributed:
AMD being unable to provide hardware ray-tracing support in Blender for 641 days and counting since the RDNA2 release.
Polaris and Vega remaining unsupported 258 days and counting after Blender 3.0+ release
RDNA currently having bugged texture support 258 days and counting after Blender 3.0+ release.
AMD GPU hardware not being competitive in cost per performance when compared to other hardware vendors.
HIP and ROCM being relatively new software.
HIP and ROCM being generally disliked by the software community (probably applies to most software).
Do you have a Vega and have you tested it? I have tested that Vega 64 support you claim to be there, and it’s a broken pile of garbage. Still getting the same error and there’s still no ETA on it getting fixed.
