i tried to load my custom keymap from previous version on the new build and i get these errors…does that mean it won’t work anymore due to new changes of keymap code?is this just a temporary problem when later i can keep my own modified version without starting from scratch?
You’ll need to update the script, it is a matter of doing some find & replace in a text editor.
SELECTMOUSE, ACTIONMOUSE, EVT_TWEAK_S and EVT_TWEAK_A should be respectively:
- LEFTMOUSE, RIGHTMOUSE, EVT_TWEAK_L and EVT_TWEAK_R (if you have left click select)
- RIGHTMOUSE, LEFTMOUSE, EVT_TWEAK_R and EVT_TWEAK_L (if you have right click select)
