Wow, thanks for the super quick fix!
It is working now, but there would be one more thing to make it perfect…
Right now the naming of the cryptomatte layers in the metadata is “xxxxx.CryptoObject”.
The cryptomatte image layer in the EXR is “xxxx_CryptoObject”. For the Cryptomatte Plugin in Nuke, the naming of both the metadata and the layer, has to be the same.
So to make the plugin work correctly, one has to change the metadata inside of Nuke.
Would it be possible to change the format of the naming in the metadata to “xxxx_CryptoObject”?
This would be relevant for both 2.79 and 2.8
thanks in advance,
Joe
