I am getting consistent crashes with baking the smoke/fire simulations which happens couple frames into the baking process. This seems to be somewhat related to some addons enabled / settings (given factory default does not crash when baking) but I am not able pinpoint the exact addon or the exact settings that might cause the problem. I am hoping someone might offer an insight looking into this log which I got with --debug-all
flag. I am also wondering if there is a bug here.
[SCScene :: View Layer]: BKE_object_eval_uber_data on OBTestMesh (00000235FC356B38)
[SCScene :: View Layer]: BKE_object_handle_data_update on OBTestMesh (00000235FC356B38)
[SCScene :: View Layer]: BKE_mesh_eval_geometry on MECube (00000235A88560B8)
[SCScene :: View Layer]: BKE_object_data_select_update on MECube (00000235A88560B8)
[SCScene :: View Layer]: BKE_object_eval_ptcache_reset on OBDomain (00000235FC355D38)
[SCScene :: View Layer]: BKE_object_eval_uber_data on OBDomain (00000235FC355D38)
[SCScene :: View Layer]: BKE_object_handle_data_update on OBDomain (00000235FC355D38)
Depsgraph updated in 0.006344 seconds.
Depsgraph evaluation FPS: 0.406822
recalcob TestMesh
UI_menutype_draw: opening menu "TIME_MT_editor_menus"
UI_menutype_draw: opening menu "NODE_MT_editor_menus"
recalcob TestMesh
Depsgraph updated in 0.478054 seconds.
[SCScene :: View Layer]: Operation is entry point for update: GEOMETRY_EVAL()
[SCScene :: View Layer]: Operation is entry point for update: DRIVER(modifiers["Fluid"].flow_settings.texture_offset)
[SCScene :: View Layer]: Accumulated recalc bits for OBDomain: 2
[SCScene :: View Layer]: Accumulated recalc bits for OBTestMesh: 4294967295
[SCScene :: View Layer]: BKE_animsys_eval_driver on OBTestMesh (00000235FC356B38) fcu modifiers["Fluid"].flow_settings.texture_offset[0] (00000235FC0D78B8)
recalcob TestMesh
UI_menutype_draw: opening menu "TOPBAR_MT_editor_menus"
Error : EXCEPTION_ACCESS_VIOLATION
[SCScene :: View Layer]: BKE_object_eval_uber_data on OBDomain (00000235FC355D38)Address : 0x00007FF7A29B4FC7
[SCScene :: View Layer]: BKE_object_handle_data_update on OBDomain (00000235FC355D38)Module : blender.exe
Thread : 0000544c
Writing: P:\temp\delete.crash.txt
Thread : 000005ec
Thread : 00003d80
Module : blender.exeWriting: P:\temp\delete.crash.txt
Thread : 000055f0
Writing: P:\temp\delete.crash.txtError : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF7A29AC802
Thread : 00004a50
Thread : 00001390
Here is the actual written crash log.
delete.crash.txt (48 KB)
