We’re using cycles out of blender for another project and we’re upgrading to 4.1 from blender. The issue is, when compiling the cpu files like kernel.cpp the code does not compile. The error is
Severity | Code | Description | Project | File | Line | Suppression State |
Error | C2668 | ‘ccl::integrator_state_transmission_bounce’: ambiguous call to overloaded function | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\light_path.h | 91 | |
Error | C2664 | ‘ccl::float3 ccl::svm_bevel(ccl::KernelGlobals,ccl::ConstIntegratorState,ccl::ShaderData *,float,int)’: cannot convert argument 2 from ‘ConstIntegratorGenericState’ to ‘ccl::ConstIntegratorState’ | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\bevel.h | 324 | |
Error | C2664 | ‘float ccl::svm_ao(ccl::KernelGlobals,ccl::ConstIntegratorState,ccl::ShaderData *,ccl::float3,float,int,int)’: cannot convert argument 2 from ‘ConstIntegratorGenericState’ to ‘ccl::ConstIntegratorState’ | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\ao.h | 123 | |
Error | C2664 | ‘void ccl::film_write_aov_pass_color(ccl::KernelGlobals,ccl::ConstIntegratorState,float *__restrict ,const int,const ccl::float3)’: cannot convert argument 2 from ‘ConstIntegratorGenericState’ to ‘ccl::ConstIntegratorState’ | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\aov.h | 31 | |
Error | C2664 | ‘void ccl::film_write_aov_pass_value(ccl::KernelGlobals,ccl::ConstIntegratorState,float *__restrict ,const int,const float)’: cannot convert argument 2 from ‘ConstIntegratorGenericState’ to ‘ccl::ConstIntegratorState’ | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\aov.h | 46 | |
Error | C2668 | ‘ccl::integrator_state_bounce’: ambiguous call to overloaded function | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\light_path.h | 59 | |
Error | C2668 | ‘ccl::integrator_state_transparent_bounce’: ambiguous call to overloaded function | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\light_path.h | 72 | |
Error | C2668 | ‘ccl::integrator_state_diffuse_bounce’: ambiguous call to overloaded function | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\light_path.h | 79 | |
Error | C2668 | ‘ccl::integrator_state_glossy_bounce’: ambiguous call to overloaded function | cycles (Cycles\cycles) | c:\work\poser\app\code\cycles\src\kernel\svm\light_path.h | 85 |
The weird thing is the code is the same in the version of cycles we have and compiles fine. It cannot determine which overload of the IntegratorStates to use. We are using 2017 15.9.55 for compile on win 11.
I cannot find any differences between the older code and this newer code for the CPU device code.
