Yes, deleted and rebuilt at least 3 times.
I don’t think it’s relevant, but cannot build on Xcode, get this error:
Here is diff output ;
joel-godinsmac:blender joelgodin$ git branch
master
* rna_curve_munits
joel-godinsmac:blender joelgodin$ git diff master
diff --git a/source/blender/makesrna/intern/rna_curve.c b/source/blender/makesrna/intern/rna_curve.c
index b92d156b674..e48930e19ca 100644
--- a/source/blender/makesrna/intern/rna_curve.c
+++ b/source/blender/makesrna/intern/rna_curve.c
@@ -1041,14 +1041,14 @@ static void rna_def_font(BlenderRNA *UNUSED(brna), StructRNA *srna)
RNA_def_property_ui_text(prop, "Shear", "Italic angle of the characters");
RNA_def_property_update(prop, 0, "rna_Curve_update_data");
- prop = RNA_def_property(srna, "offset_x", PROP_FLOAT, PROP_NONE);
+ prop = RNA_def_property(srna, "offset_x", PROP_FLOAT, PROP_DISTANCE);
RNA_def_property_float_sdna(prop, NULL, "xof");
RNA_def_property_range(prop, -FLT_MAX, FLT_MAX);
RNA_def_property_ui_range(prop, -50.0f, 50.0f, 10, 3);
RNA_def_property_ui_text(prop, "X Offset", "Horizontal offset from the object origin");
- prop = RNA_def_property(srna, "offset_y", PROP_FLOAT, PROP_NONE);
+ prop = RNA_def_property(srna, "offset_y", PROP_FLOAT, PROP_DISTANCE);
RNA_def_property_float_sdna(prop, NULL, "yof");
