Today my debug Blender build suddenly fails to compile Cycles GPU CUDA kernels for some reason.
I didn’t change any code, so I deleted my old build folder and used make debug
to create a brand new one.
However this still didn’t fix things.
The build itself succeeds but if I want to use Cycles with my GTX 1080 I get an error message on the debug console.
Full console output:
Read prefs: C:\Users\nucle\AppData\Roaming\Blender Foundation\Blender\3.5\config\userpref.blend
Vendor: NVIDIA Corporation
Renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
Version: 4.5.0 NVIDIA 517.40
Context Version: 4.5
register
WARN (rna.define): C:\Users\nucle\Desktop\SSD_Blender_Source_Code\blender\source\blender\makesrna\intern\rna_define.c:1647 RNA_def_property_ui_text: 'Global Settings.' description from 'mi_settings' '' ends with a '.' !
WARN (rna.define): C:\Users\nucle\Desktop\SSD_Blender_Source_Code\blender\source\blender\makesrna\intern\rna_define.c:1647 RNA_def_property_ui_text: 'Curve Stretch Settings.' description from 'mi_cur_stretch_settings' '' ends with a '.' !
WARN (rna.define): C:\Users\nucle\Desktop\SSD_Blender_Source_Code\blender\source\blender\makesrna\intern\rna_define.c:1647 RNA_def_property_ui_text: 'Curve Surfaces Settings.' description from 'mi_cur_surfs_settings' '' ends with a '.' !
WARN (rna.define): C:\Users\nucle\Desktop\SSD_Blender_Source_Code\blender\source\blender\makesrna\intern\rna_define.c:1239 RNA_def_struct_ui_text: 'Divide selected edges or faces inserting new edges between them, and optionally spread the new edges.' description from 'FORGOTTEN_OT_mesh_connect_spread' '' ends with a '.' !
CUDA version 11.8 detected, build may succeed but only CUDA 10.1 to 11.4 are officially supported.
Compiling CUDA kernel ...
"nvcc" -arch=sm_61 --cubin "C:\Users\nucle\Desktop\SSD_Blender_Source_Code\build_windows_x64_vc17_Debug\bin\Debug\3.5\scripts\addons\cycles\source\kernel\device\cuda\kernel.cu" -o "C:\Users\nucle\AppData\Roaming\Blender Foundation\Blender\3.5\cache\kernels\cycles_kernel_sm_61_CF7E77A0CDE6C538FDAE549F5A0006EC.cubin" -m64 --ptxas-options="-v" --use_fast_math -DNVCC -I"C:\Users\nucle\Desktop\SSD_Blender_Source_Code\build_windows_x64_vc17_Debug\bin\Debug\3.5\scripts\addons\cycles\source" -DWITH_NANOVDB
nvcc fatal : Cannot find compiler 'cl.exe' in PATH
Failed to execute compilation command, see console for details.
Refer to the Cycles GPU rendering documentation for possible solutions:
https://docs.blender.org/manual/en/latest/render/cycles/gpu_rendering.html
Failed to unregister <class 'Texel_Density_3_2_2_291.ui.VIEW3D_PT_texel_density_checker'>
File "C:\Users\nucle\AppData\Roaming\Blender Foundation\Blender\3.5\scripts\addons\simple-tabs\addon\utils\sidebar.py", line 118, in update
bpy.utils.unregister_class(panel)
RuntimeError: unregister_class(...):, missing bl_rna attribute from 'RNAMeta' instance (may not be registered)
Info: Updated sidebar tabs
What’s strange is up until now it has always worked and I didn’t change anything, it just suddenly stopped working.
How do I fix this?
