Hi folks!
I posted it as a bug T61838, but now I think this is a better place for such discussion.
Don’t know is this a bug or not, got script from here: T54099. Can’t activate all Cycles Render Devices from script on first try.
Add script to Text Editor and run it.
Open file menu in topbar -> Press Load DotBow Config -> Check Cycles Render Devices in settings, only GPU is selected.
Repeat steps and check Cycles Render Devices again - all devices active.
import bpy
class TOPBAR_OT_load_dotbow_config(bpy.types.Operator):
bl_idname = "wm.load_dotbow_config"
bl_label = "Load DotBow Config"
def execute(self, context):
# bpy.ops.wm.read_factory_settings()
scene = bpy.context.scene
scene.cycles.device = 'GPU'
prefs = bpy.context.preferences
cprefs = prefs.addons['cycles'].preferences
# Attempt to set GPU device types if available
for compute_device_type in ('CUDA', 'OPENCL', 'NONE'):
try:
cprefs.compute_device_type = compute_device_type
break
except TypeError:
pass
# Enable all CPU and GPU devices
for device in cprefs.devices:
device.use = True
# bpy.ops.wm.save_homefile()
return {'FINISHED'}
def menu_func(self, context):
layout = self.layout
layout.operator(TOPBAR_OT_load_dotbow_config.bl_idname)
classes = (
TOPBAR_OT_load_dotbow_config,
def register():
for cls in classes:
bpy.utils.register_class(cls)
bpy.types.TOPBAR_MT_file.prepend(menu_func)
def unregister():
for cls in reversed(classes):
bpy.utils.unregister_class(cls)
bpy.types.TOPBAR_MT_file.remove(menu_func)
if __name__ == "__main__":
register()
