once the addon is installed it will appear in the addons list as 3di test addon template, and pressing ctrl shift f should popup up a menu with a few simple tools in it (add monkey, solidify, set origin of all selected to each geometry)
Hi, checked with 2.91 on Opensuse Tumbleweed, I can install the addon but not enable it.
./blender
Read prefs: /home/xxx/.config/blender/2.91/config/userpref.blend
found bundled python: /home/xxx/blender-2.91.0-linux64/2.91/python
addon_utils.disable: latest template not disabled
Modules Installed (latest template) from '/home/xxx/Downloads/3di_test_addon_template.zip' into '/home/xxx/.config/blender/2.91/scripts/addons'
File "/home/xxx/blender-2.91.0-linux64/2.91/scripts/modules/addon_utils.py", line 351, in enable
mod = __import__(module_name)
File "/home/xxx/.config/blender/2.91/scripts/addons/latest template/__init__.py", line 27, in <module>
from . utils import RegisterHelpers as rh
File "/home/xxx/.config/blender/2.91/scripts/addons/latest template/utils/RegisterHelpers.py", line 39, in <module>
all_mods = get_all_modules_defined_in_directory(directory,all_mods)#get the folder contents for the current directory looping over and overwrite all_mods (list of all modules)
File "/home/xxx/.config/blender/2.91/scripts/addons/latest template/utils/RegisterHelpers.py", line 17, in get_all_modules_defined_in_directory
folder_contents = os.listdir(str(pathlib.Path(__file__).parent.parent.parent.absolute()) +'\\'+ directory)
FileNotFoundError: [Errno 2] No such file or directory: '/home/xxx/.config/blender/2.91/scripts/addons\\latest template\\properties\\'
I’m on Mac OS 10.14.6 and tested your template with Blender 2.91. Seems to be doing exactly what you described using your newer version latest_template_v2.zip.
(Trying the first one you posted gave me the same error that mib3berlin got.)
