trying to build this branch for Graphicall.
So far I have a working build without statically linked libraries but I’ve been asked to do it with them.
For starters, I had to checkout an early version of the branch because the newer ones didn’t work at all:
git checkout 'uv_unwrapping_slim_algorithm'
git checkout 'uv_unwrapping_slim_algorithm@{2017-05-24 17:23:54}'
I also skipped osl in install_deps.sh because I couldn’t get it to work either (that’s not a problem since osl is not related to the SLIM algorithm)
./build_files/build_environment/install_deps.sh --skip-osl
then I ran the long make command it gave me, went in build_linux/CMakeCache.txt and set:
WITH_STATIC_LIBS:BOOL=ON
and run make in the build_linux directory and I got this: https://pastebin.com/p8xedBwe
