pq1
September 10, 2019, 3:48pm
1
Howdy friends.
I build my own Blender 2.81 daily. I tried using the OpenImageDenoise node but it seems deactivated by default. Anyone knows how I can build Blender with OpenImageDenoise activated?
My current build steps in Windows are:
Copy to clipboard
make update
make release
Thanks a ton!
P
NiCapp
September 10, 2019, 6:05pm
2
on my linux compiled version OIDN work fine, my recipe is:
make deps
make update
make full release
pq1
September 15, 2019, 2:09am
3
Hey NiCapp. I tried
make deps
But it is not an option in Windows. I hope some one will share their Windows experience here.
P
Znio.G
September 15, 2019, 4:54am
4
IOID builds with Blender and the flag is in CmakeLists file, u don’t have to build it yourself.
option(WITH_OPENIMAGEDENOISE “Enable the OpenImageDenoise compositing…”
This is from their website,check your CPU instructions that’s probably the reason why the Node is deactivated.
Your CPU must support at least SSE4.1 to run Open Image Denoise,
pq1
September 15, 2019, 2:40pm
5
Thanks Zinio. I like building myself instead of downloading and then deleting the old version and adding the new download daily build.
The CPU works fine with OpenImageDenoise. I’ve used the daily builds from Blender.org it works great for denoising.
I just want to build it myself.
P
The libs you have are the same libs the build bot uses, so there’s no reason to be building them your self.
In your build folder you should have a CMakeCache.txt
file, open it up in a text editor and look for this snippet
//Enable the OpenImageDenoise compositing node
WITH_OPENIMAGEDENOISE:BOOL=ON
and validate that it is indeed on.
pq1
September 15, 2019, 3:19pm
7
Thanks LazyDodo. I found it on
C:\blender-git\build_windows_Release_x64_vc16_Release
And indeed was OFF. Changed it to ON and now compiling. Will report the result in case someone else has the same question.
P
pq1
September 15, 2019, 3:47pm
8
Well, I built it again after changing OPENIMAGEDENOISE to ON inside
CMakeCache.txt
Unfortunately the Denoise composition node still says
Disabled, built without OpenImageDenoise
How else can I troubleshoot this?
P
Try deleting your complete build folder and see if it works it self out.
pq1
September 15, 2019, 4:39pm
10
After deleting the folder and re-building, the OpenImageDenoise node is active!
Thanks.
P
