Sorry, the post above leaves out the line continuations in the export command. The attached file should be clearer.my-make.txt (707 Bytes)
So I took a clean environment as usual and I tried the following: CC=clang CXX=clang++ make BUILD_CMAKE_ARGS="..."
and it looks like OSL is having problems to link. Was that command correct, or should I use something else?
Linking log:
[100%] Linking CXX executable ../../bin/blender
[100%] Building CXX object intern/cycles/app/CMakeFiles/cycles.dir/cycles_xml.cpp.o
[100%] Linking CXX executable ../../../bin/cycles
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `OSL_v1_10::pvt::OSLCompilerImpl::write_oso_const_value(OSL_v1_10::pvt::ConstantSymbol const*) const':
oslcomp.cpp:(.text+0x10e5): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
oslcomp.cpp:(.text+0x12a6): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
oslcomp.cpp:(.text+0x1492): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
oslcomp.cpp:(.text+0x1653): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `OSL_v1_10::pvt::OSLCompilerImpl::write_oso_metadata(OSL_v1_10::pvt::ASTNode const*) const':
oslcomp.cpp:(.text+0x4814): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o):oslcomp.cpp:(.text+0x4d8b): more undefined references to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()' follow
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void boost::wave::util::throw_<boost::wave::preprocess_exception, boost::wave::context<__gnu_cxx::__normal_iterator<char*, std::string>, boost::wave::cpplexer::lex_iterator<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::iteration_context_policies::load_file_to_string, boost::wave::context_policies::eat_whitespace<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::this_type>, char const*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > >(boost::wave::context<__gnu_cxx::__normal_iterator<char*, std::string>, boost::wave::cpplexer::lex_iterator<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::iteration_context_policies::load_file_to_string, boost::wave::context_policies::eat_whitespace<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::this_type>&, boost::wave::preprocess_exception::error_code, char const*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > const&)':
oslcomp.cpp:(.text._ZN5boost4wave4util6throw_INS0_20preprocess_exceptionENS0_7contextIN9__gnu_cxx17__normal_iteratorIPcSsEENS0_8cpplexer12lex_iteratorINS9_9lex_tokenINS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSG_EES7_EEEEEEEEEENS0_26iteration_context_policies19load_file_to_stringENS0_16context_policies14eat_whitespaceISN_EENS0_9this_typeEEEPKcSM_EEvRT0_NT_10error_codeET1_RKT2_[_ZN5boost4wave4util6throw_INS0_20preprocess_exceptionENS0_7contextIN9__gnu_cxx17__normal_iteratorIPcSsEENS0_8cpplexer12lex_iteratorINS9_9lex_tokenINS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSG_EES7_EEEEEEEEEENS0_26iteration_context_policies19load_file_to_stringENS0_16context_policies14eat_whitespaceISN_EENS0_9this_typeEEEPKcSM_EEvRT0_NT_10error_codeET1_RKT2_]+0x2d): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void boost::wave::util::throw_<boost::wave::macro_handling_exception, char const*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > >, char const*>(boost::wave::macro_handling_exception::error_code, char const*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > const&, char const*)':
oslcomp.cpp:(.text._ZN5boost4wave4util6throw_INS0_24macro_handling_exceptionEPKcNS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSA_EEPcEEEEEES5_EEvNT_10error_codeET0_RKT1_T2_[_ZN5boost4wave4util6throw_INS0_24macro_handling_exceptionEPKcNS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSA_EEPcEEEEEES5_EEvNT_10error_codeET0_RKT1_T2_]+0x31): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void tinyformat::detail::formatTruncated<int>(std::ostream&, int const&, int)':
oslcomp.cpp:(.text._ZN10tinyformat6detail15formatTruncatedIiEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedIiEEvRSoRKT_i]+0x2a): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void tinyformat::detail::formatTruncated<OpenImageIO_v2_1::ustring>(std::ostream&, OpenImageIO_v2_1::ustring const&, int)':
oslcomp.cpp:(.text._ZN10tinyformat6detail15formatTruncatedIN16OpenImageIO_v2_17ustringEEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedIN16OpenImageIO_v2_17ustringEEEvRSoRKT_i]+0x2a): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void tinyformat::detail::formatTruncated<std::string>(std::ostream&, std::string const&, int)':
oslcomp.cpp:(.text._ZN10tinyformat6detail15formatTruncatedISsEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedISsEEvRSoRKT_i]+0x2a): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void boost::wave::util::throw_<boost::wave::preprocess_exception, boost::wave::context<__gnu_cxx::__normal_iterator<char*, std::string>, boost::wave::cpplexer::lex_iterator<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::iteration_context_policies::load_file_to_string, boost::wave::context_policies::eat_whitespace<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::this_type>, char*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > >(boost::wave::context<__gnu_cxx::__normal_iterator<char*, std::string>, boost::wave::cpplexer::lex_iterator<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::iteration_context_policies::load_file_to_string, boost::wave::context_policies::eat_whitespace<boost::wave::cpplexer::lex_token<boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > > >, boost::wave::this_type>&, boost::wave::preprocess_exception::error_code, char*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > const&)':
oslcomp.cpp:(.text._ZN5boost4wave4util6throw_INS0_20preprocess_exceptionENS0_7contextIN9__gnu_cxx17__normal_iteratorIPcSsEENS0_8cpplexer12lex_iteratorINS9_9lex_tokenINS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSG_EES7_EEEEEEEEEENS0_26iteration_context_policies19load_file_to_stringENS0_16context_policies14eat_whitespaceISN_EENS0_9this_typeEEES7_SM_EEvRT0_NT_10error_codeET1_RKT2_[_ZN5boost4wave4util6throw_INS0_20preprocess_exceptionENS0_7contextIN9__gnu_cxx17__normal_iteratorIPcSsEENS0_8cpplexer12lex_iteratorINS9_9lex_tokenINS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSG_EES7_EEEEEEEEEENS0_26iteration_context_policies19load_file_to_stringENS0_16context_policies14eat_whitespaceISN_EENS0_9this_typeEEES7_SM_EEvRT0_NT_10error_codeET1_RKT2_]+0x2d): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void tinyformat::detail::formatTruncated<float>(std::ostream&, float const&, int)':
oslcomp.cpp:(.text._ZN10tinyformat6detail15formatTruncatedIfEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedIfEEvRSoRKT_i]+0x2a): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void tinyformat::detail::formatTruncated<OpenImageIO_v2_1::string_view>(std::ostream&, OpenImageIO_v2_1::string_view const&, int)':
oslcomp.cpp:(.text._ZN10tinyformat6detail15formatTruncatedIN16OpenImageIO_v2_111string_viewEEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedIN16OpenImageIO_v2_111string_viewEEEvRSoRKT_i]+0x2a): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(oslcomp.cpp.o): In function `void boost::wave::cpplexer::impl::validate_literal<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > >(boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > const&, unsigned long, unsigned long, boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > const&)':
oslcomp.cpp:(.text._ZN5boost4wave8cpplexer4impl16validate_literalINS0_4util11flex_stringIcSt11char_traitsIcESaIcENS4_9CowStringINS4_22AllocatorStringStorageIcS8_EEPcEEEEEEvRKT_mmSH_[_ZN5boost4wave8cpplexer4impl16validate_literalINS0_4util11flex_stringIcSt11char_traitsIcESaIcENS4_9CowStringINS4_22AllocatorStringStorageIcS8_EEPcEEEEEEvRKT_mmSH_]+0x1c8): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
oslcomp.cpp:(.text._ZN5boost4wave8cpplexer4impl16validate_literalINS0_4util11flex_stringIcSt11char_traitsIcESaIcENS4_9CowStringINS4_22AllocatorStringStorageIcS8_EEPcEEEEEEvRKT_mmSH_[_ZN5boost4wave8cpplexer4impl16validate_literalINS0_4util11flex_stringIcSt11char_traitsIcESaIcENS4_9CowStringINS4_22AllocatorStringStorageIcS8_EEPcEEEEEEvRKT_mmSH_]+0x361): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(typecheck.cpp.o): In function `OSL_v1_10::pvt::ASTfunction_call::typecheck_struct_constructor()':
typecheck.cpp:(.text+0x3daa): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(typecheck.cpp.o): In function `OSL_v1_10::pvt::ASTfunction_call::typecheck_printf_args(char const*, OSL_v1_10::pvt::ASTNode*)':
typecheck.cpp:(.text+0x5ceb): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(typecheck.cpp.o): In function `OSL_v1_10::pvt::ASTcompound_initializer::TypeAdjuster::typecheck(OpenImageIO_v2_1::intrusive_ptr<OSL_v1_10::pvt::ASTNode>, OSL_v1_10::pvt::TypeSpec, OSL_v1_10::pvt::StructSpec const*, OSL_v1_10::pvt::StructSpec::FieldSpec const*)':
typecheck.cpp:(.text._ZN9OSL_v1_103pvt23ASTcompound_initializer12TypeAdjuster9typecheckEN16OpenImageIO_v2_113intrusive_ptrINS0_7ASTNodeEEENS0_8TypeSpecEPKNS0_10StructSpecEPKNS8_9FieldSpecE[_ZN9OSL_v1_103pvt23ASTcompound_initializer12TypeAdjuster9typecheckEN16OpenImageIO_v2_113intrusive_ptrINS0_7ASTNodeEEENS0_8TypeSpecEPKNS0_10StructSpecEPKNS8_9FieldSpecE]+0x110): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
typecheck.cpp:(.text._ZN9OSL_v1_103pvt23ASTcompound_initializer12TypeAdjuster9typecheckEN16OpenImageIO_v2_113intrusive_ptrINS0_7ASTNodeEEENS0_8TypeSpecEPKNS0_10StructSpecEPKNS8_9FieldSpecE[_ZN9OSL_v1_103pvt23ASTcompound_initializer12TypeAdjuster9typecheckEN16OpenImageIO_v2_113intrusive_ptrINS0_7ASTNodeEEENS0_8TypeSpecEPKNS0_10StructSpecEPKNS8_9FieldSpecE]+0x20a): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(typecheck.cpp.o): In function `OSL_v1_10::pvt::CandidateFunctions::reportFunction(OSL_v1_10::pvt::FunctionSymbol*) const':
typecheck.cpp:(.text._ZNK9OSL_v1_103pvt18CandidateFunctions14reportFunctionEPNS0_14FunctionSymbolE[_ZNK9OSL_v1_103pvt18CandidateFunctions14reportFunctionEPNS0_14FunctionSymbolE]+0xf9): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslcomp.a(typecheck.cpp.o):typecheck.cpp:(.text._ZN9OSL_v1_103pvt23ASTcompound_initializer12TypeAdjuster16typecheck_fieldsEPNS0_7ASTNodeEN16OpenImageIO_v2_113intrusive_ptrIS3_EENS0_8TypeSpecE[_ZN9OSL_v1_103pvt23ASTcompound_initializer12TypeAdjuster16typecheck_fieldsEPNS0_7ASTNodeEN16OpenImageIO_v2_113intrusive_ptrIS3_EENS0_8TypeSpecE]+0x433): more undefined references to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()' follow
/content/lib/linux_centos7_x86_64/osl/lib/liboslexec.a(context.cpp.o): In function `std::_Sp_counted_ptr_inplace<std::__detail::_NFA<std::regex_traits<char> >, std::allocator<std::__detail::_NFA<std::regex_traits<char> > >, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
context.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceINSt8__detail4_NFAISt12regex_traitsIcEEESaIS4_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceINSt8__detail4_NFAISt12regex_traitsIcEEESaIS4_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/osl/lib/liboslexec.a(context.cpp.o): In function `void tinyformat::detail::formatTruncated<OSL_v1_10::ShadingContext*>(std::ostream&, OSL_v1_10::ShadingContext* const&, int)':
context.cpp:(.text._ZN10tinyformat6detail15formatTruncatedIPN9OSL_v1_1014ShadingContextEEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedIPN9OSL_v1_1014ShadingContextEEEvRSoRKT_i]+0x33): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslexec.a(context.cpp.o): In function `void tinyformat::detail::formatTruncated<unsigned long long>(std::ostream&, unsigned long long const&, int)':
context.cpp:(.text._ZN10tinyformat6detail15formatTruncatedIyEEvRSoRKT_i[_ZN10tinyformat6detail15formatTruncatedIyEEvRSoRKT_i]+0x33): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslexec.a(constfold.cpp.o): In function `OSL_v1_10::pvt::constfold_format(OSL_v1_10::pvt::RuntimeOptimizer&, int)':
constfold.cpp:(.text+0x1186b): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
constfold.cpp:(.text+0x11c17): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
constfold.cpp:(.text+0x1210d): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/osl/lib/liboslexec.a(constfold.cpp.o):constfold.cpp:(.text+0x12235): more undefined references to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()' follow
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMRuntimeDyld.a(RuntimeDyld.cpp.o): In function `std::_Sp_counted_ptr_inplace<std::__future_base::_State_baseV2, std::allocator<std::__future_base::_State_baseV2>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
RuntimeDyld.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceINSt13__future_base13_State_baseV2ESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceINSt13__future_base13_State_baseV2ESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMRuntimeDyld.a(RuntimeDyld.cpp.o): In function `std::_Sp_counted_ptr_inplace<std::promise<llvm::Expected<std::map<llvm::StringRef, llvm::JITEvaluatedSymbol, std::less<llvm::StringRef>, std::allocator<std::pair<llvm::StringRef const, llvm::JITEvaluatedSymbol> > > > >, std::allocator<std::promise<llvm::Expected<std::map<llvm::StringRef, llvm::JITEvaluatedSymbol, std::less<llvm::StringRef>, std::allocator<std::pair<llvm::StringRef const, llvm::JITEvaluatedSymbol> > > > > >, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
RuntimeDyld.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceISt7promiseIN4llvm8ExpectedISt3mapINS1_9StringRefENS1_18JITEvaluatedSymbolESt4lessIS4_ESaISt4pairIKS4_S5_EEEEEESaISE_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceISt7promiseIN4llvm8ExpectedISt3mapINS1_9StringRefENS1_18JITEvaluatedSymbolESt4lessIS4_ESaISt4pairIKS4_S5_EEEEEESaISE_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMDebugInfoDWARF.a(DWARFContext.cpp.o): In function `std::_Sp_counted_ptr_inplace<llvm::DWARFContext::DWOFile, std::allocator<llvm::DWARFContext::DWOFile>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
DWARFContext.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN4llvm12DWARFContext7DWOFileESaIS2_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceIN4llvm12DWARFContext7DWOFileESaIS2_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMBitWriter.a(BitcodeWriter.cpp.o): In function `std::_Sp_counted_ptr_inplace<llvm::BitCodeAbbrev, std::allocator<llvm::BitCodeAbbrev>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
BitcodeWriter.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN4llvm13BitCodeAbbrevESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceIN4llvm13BitCodeAbbrevESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/opencolorio/lib/libOpenColorIO.a(Config.cpp.o): In function `OpenColorIO::v1::Config::sanityCheck() const':
Config.cpp:(.text+0x7b8d): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
Config.cpp:(.text+0x7cd9): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
Config.cpp:(.text+0x7dcc): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
Config.cpp:(.text+0x8c50): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
Config.cpp:(.text+0x8d22): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/opencolorio/lib/libOpenColorIO.a(Config.cpp.o):Config.cpp:(.text+0x8e82): more undefined references to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()' follow
/content/lib/linux_centos7_x86_64/opencolorio/lib/libOpenColorIO.a(OCIOYaml.cpp.o): In function `OpenColorIO::v1::(anonymous namespace)::save(YAML::Emitter&, std::tr1::shared_ptr<OpenColorIO::v1::Transform const>)':
OCIOYaml.cpp:(.text+0x1859): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
OCIOYaml.cpp:(.text+0x26b2): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
OCIOYaml.cpp:(.text+0x3588): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
//etc...(omitted_due_to_devatalk_message_limit)
proxyTypes.cpp:(.text._ZNK25usdBlender__pxrReserved__14Sdf_ListEditorINS_22SdfReferenceTypePolicyEE13_ValidateEditENS_13SdfListOpTypeERKSt6vectorINS_12SdfReferenceESaIS5_EES9_[_ZNK25usdBlender__pxrReserved__14Sdf_ListEditorINS_22SdfReferenceTypePolicyEE13_ValidateEditENS_13SdfListOpTypeERKSt6vectorINS_12SdfReferenceESaIS5_EES9_]+0xe6): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/usd/lib/libusd_m.a(changes.cpp.o): In function `usdBlender__pxrReserved__::PcpChanges::DidChange(usdBlender__pxrReserved__::TfSpan<usdBlender__pxrReserved__::PcpCache const*> const&, std::vector<std::pair<usdBlender__pxrReserved__::TfWeakPtr<usdBlender__pxrReserved__::SdfLayer>, usdBlender__pxrReserved__::SdfChangeList>, std::allocator<std::pair<usdBlender__pxrReserved__::TfWeakPtr<usdBlender__pxrReserved__::SdfLayer>, usdBlender__pxrReserved__::SdfChangeList> > > const&)':
changes.cpp:(.text+0x51a6): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
changes.cpp:(.text+0x57c2): undefined reference to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/content/lib/linux_centos7_x86_64/usd/lib/libusd_m.a(changes.cpp.o):changes.cpp:(.text._ZN25usdBlender__pxrReserved__11TfStringifyINS_9TfWeakPtrINS_13PcpLayerStackEEEEENSt9enable_ifIXntsrSt7is_enumIT_E5valueESsE4typeERKS6_[_ZN25usdBlender__pxrReserved__11TfStringifyINS_9TfWeakPtrINS_13PcpLayerStackEEEEENSt9enable_ifIXntsrSt7is_enumIT_E5valueESsE4typeERKS6_]+0x1b): more undefined references to `std::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()' follow
/content/lib/linux_centos7_x86_64/embree/lib/libembree3.a(bvh.cpp.o): In function `embree::FastAllocator::Statistics::str(unsigned long)':
bvh.cpp:(.text._ZN6embree13FastAllocator10Statistics3strEm[_ZN6embree13FastAllocator10Statistics3strEm]+0x26): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/embree/lib/libembree3.a(bvh.cpp.o): In function `embree::FastAllocator::AllStatistics::print(unsigned long)':
bvh.cpp:(.text._ZN6embree13FastAllocator13AllStatistics5printEm[_ZN6embree13FastAllocator13AllStatistics5printEm]+0x2a): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
bvh.cpp:(.text._ZN6embree13FastAllocator13AllStatistics5printEm[_ZN6embree13FastAllocator13AllStatistics5printEm]+0x1ab): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMMCJIT.a(MCJIT.cpp.o): In function `std::_Sp_counted_ptr_inplace<llvm::SectionMemoryManager, std::allocator<llvm::SectionMemoryManager>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
MCJIT.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN4llvm20SectionMemoryManagerESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceIN4llvm20SectionMemoryManagerESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMCore.a(DiagnosticHandler.cpp.o): In function `std::_Sp_counted_ptr_inplace<llvm::Regex, std::allocator<llvm::Regex>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
DiagnosticHandler.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN4llvm5RegexESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceIN4llvm5RegexESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/boost/lib/libboost_wave.a(instantiate_cpp_exprgrammar.o): In function `void boost::wave::util::throw_<boost::wave::preprocess_exception, char const*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > >(boost::wave::preprocess_exception::error_code, char const*, boost::wave::util::file_position<boost::wave::util::flex_string<char, std::char_traits<char>, std::allocator<char>, boost::wave::util::CowString<boost::wave::util::AllocatorStringStorage<char, std::allocator<char> >, char*> > > const&)':
instantiate_cpp_exprgrammar.cpp:(.text._ZN5boost4wave4util6throw_INS0_20preprocess_exceptionEPKcNS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSA_EEPcEEEEEEEEvNT_10error_codeET0_RKT1_[_ZN5boost4wave4util6throw_INS0_20preprocess_exceptionEPKcNS1_13file_positionINS1_11flex_stringIcSt11char_traitsIcESaIcENS1_9CowStringINS1_22AllocatorStringStorageIcSA_EEPcEEEEEEEEvNT_10error_codeET0_RKT1_]+0x2d): undefined reference to `std::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::basic_stringstream()'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMSupport.a(BinaryStreamRef.cpp.o): In function `std::_Sp_counted_ptr_inplace<(anonymous namespace)::ArrayRefImpl, std::allocator<(anonymous namespace)::ArrayRefImpl>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
BinaryStreamRef.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN12_GLOBAL__N_112ArrayRefImplESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMSupport.a(BinaryStreamRef.cpp.o): In function `std::_Sp_counted_ptr_inplace<(anonymous namespace)::MutableArrayRefImpl, std::allocator<(anonymous namespace)::MutableArrayRefImpl>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
BinaryStreamRef.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN12_GLOBAL__N_119MutableArrayRefImplESaIS1_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
/content/lib/linux_centos7_x86_64/llvm/lib/libLLVMSupport.a(Path.cpp.o): In function `std::_Sp_counted_ptr_inplace<llvm::sys::fs::detail::DirIterState, std::allocator<llvm::sys::fs::detail::DirIterState>, (__gnu_cxx::_Lock_policy)2>::_M_get_deleter(std::type_info const&)':
Path.cpp:(.text._ZNSt23_Sp_counted_ptr_inplaceIN4llvm3sys2fs6detail12DirIterStateESaIS4_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info[_ZNSt23_Sp_counted_ptr_inplaceIN4llvm3sys2fs6detail12DirIterStateESaIS4_ELN9__gnu_cxx12_Lock_policyE2EE14_M_get_deleterERKSt9type_info]+0x13): undefined reference to `std::_Sp_make_shared_tag::_S_eq(std::type_info const&)'
clang: error: linker command failed with exit code 1 (use -v to see invocation)
source/creator/CMakeFiles/blender.dir/build.make:428: recipe for target 'bin/blender' failed
make[3]: *** [bin/blender] Error 1
CMakeFiles/Makefile2:7973: recipe for target 'source/creator/CMakeFiles/blender.dir/all' failed
make[2]: *** [source/creator/CMakeFiles/blender.dir/all] Error 2
Makefile:162: recipe for target 'all' failed
make[1]: *** [all] Error 2
GNUmakefile:308: recipe for target 'all' failed
make: *** [all] Error 2
Please upload CmakeCache.txt file.
Also the output of clang -v
clang version 6.0.0-1ubuntu2 (tags/RELEASE_600/final)
Target: x86_64-pc-linux-gnu
Thread model: posix
InstalledDir: /usr/bin
Found candidate GCC installation: /usr/bin/../lib/gcc/x86_64-linux-gnu/7
Found candidate GCC installation: /usr/bin/../lib/gcc/x86_64-linux-gnu/7.5.0
Found candidate GCC installation: /usr/bin/../lib/gcc/x86_64-linux-gnu/8
Found candidate GCC installation: /usr/lib/gcc/x86_64-linux-gnu/7
Found candidate GCC installation: /usr/lib/gcc/x86_64-linux-gnu/7.5.0
Found candidate GCC installation: /usr/lib/gcc/x86_64-linux-gnu/8
Selected GCC installation: /usr/bin/../lib/gcc/x86_64-linux-gnu/8
Candidate multilib: .;@m64
Selected multilib: .;@m64
Found CUDA installation: /usr/local/cuda, version unknown
Ok, thank you for pointing that out. I never had to deal with that as I was using gcc. I will upgrade and report success or failure.
At the beginning I got the following warnings at the beginning:
CMake Warning at /usr/local/lib/python2.7/dist-packages/cmake/data/share/cmake-3.12/Modules/FindBoost.cmake:847 (message):
New Boost version may have incorrect or missing dependencies and imported
targets
Call Stack (most recent call first):
/usr/local/lib/python2.7/dist-packages/cmake/data/share/cmake-3.12/Modules/FindBoost.cmake:959 (_Boost_COMPONENT_DEPENDENCIES)
/usr/local/lib/python2.7/dist-packages/cmake/data/share/cmake-3.12/Modules/FindBoost.cmake:1618 (_Boost_MISSING_DEPENDENCIES)
build_files/cmake/platform/platform_unix.cmake:310 (find_package)
CMakeLists.txt:830 (include)
-- Boost version: 1.70.0
-- Found the following Boost libraries:
-- filesystem
-- regex
-- thread
-- date_time
-- wave
-- iostreams
-- system
-- chrono
-- atomic
-- serialization
-- Could NOT find OpenMP_C (missing: OpenMP_C_FLAGS OpenMP_C_LIB_NAMES)
-- Could NOT find OpenMP_CXX (missing: OpenMP_CXX_FLAGS OpenMP_CXX_LIB_NAMES)
-- Could NOT find OpenMP (missing: OpenMP_C_FOUND OpenMP_CXX_FOUND)
-- CUDA nvcc = /usr/local/cuda/bin/nvcc
-- Tests: Using Python executable: /content/lib/linux_centos7_x86_64/python/bin/python3.7m
-- Disabling render tests because tests folder does not exist at /content/blender/../lib/tests
-- Configuring done
-- Generating done
-- Build files have been written to: /content/build_linux
At the end the linking failed with the same errors I pasted above. Attached the CMakeCache.txt. I didn’t make a clean run this time, but I can repeat with a clean run if that could help.
CMakeCache.txt (93.2 KB)
Update: I started a clean build and it looks better. At least the OpenMP issues are gone now. Let’s see at the linking stage.
So using clang-10 and a clean build environment, linking ended up crashing with just the same errors as I pasted above. Attached relevant cmake logs.
CMakeCache(1).txt (94.3 KB) CMakeOutput.txt (128.2 KB) CMakeError.txt (3.3 KB)
intern/cycles/app/CMakeFiles/cycles.dir/build.make:356: recipe for target 'bin/cycles' failed
source/creator/CMakeFiles/blender.dir/build.make:429: recipe for target 'bin/blender' failed
Could you try -DWITH_CXX_ABI=OFF
-DWITH_CXX11_ABI=OFF
cd build_folder
cmake -DWITH_CXX_ABI=OFF -DWITH_CXX11_ABI=OFF .
make
Unfortunately not - it’s the same error. Note that I am now using BUILD_CMAKE_ARGS="-D WITH_CXX_ABI=OFF -D WITH_CXX11_ABI=OFF [but also] -D WITH_CYCLES_OSL=ON -D WITH_CYCLES_STANDALONE=ON [and some other switches ... ]"
Updates:
I managed to install both
gcc-8
andgcc-9
(on Ubuntu 18.04). The key was to installgcc-9
first andgcc-8
after that. CUDA requiresgcc-8
and fails with a different version, but Blender now requires a different version. -
The build went better, but it still fails. Now with a different error!
[100%] Built target cycles
../../lib/libbf_intern_eigen.a(linear_solver.cc.o):linear_solver.cc:function Eigen::internal::sparse_time_dense_product_impl<Eigen::Transpose<Eigen::SparseMatrix<double, 0, int> >, Eigen::Matrix<double, -1, 1, 0, -1, 1>, Eigen::Matrix<double, -1, 1, 0, -1, 1>, double, 1, true>::run(Eigen::Transpose<Eigen::SparseMatrix<double, 0, int> > const&, Eigen::Matrix<double, -1, 1, 0, -1, 1> const&, Eigen::Matrix<double, -1, 1, 0, -1, 1>&, double const&) [clone ._omp_fn.0]: error: undefined reference to 'GOMP_loop_nonmonotonic_dynamic_start'
../../lib/libbf_intern_eigen.a(linear_solver.cc.o):linear_solver.cc:function Eigen::internal::sparse_time_dense_product_impl<Eigen::Transpose<Eigen::SparseMatrix<double, 0, int> >, Eigen::Matrix<double, -1, 1, 0, -1, 1>, Eigen::Matrix<double, -1, 1, 0, -1, 1>, double, 1, true>::run(Eigen::Transpose<Eigen::SparseMatrix<double, 0, int> > const&, Eigen::Matrix<double, -1, 1, 0, -1, 1> const&, Eigen::Matrix<double, -1, 1, 0, -1, 1>&, double const&) [clone ._omp_fn.0]: error: undefined reference to 'GOMP_loop_nonmonotonic_dynamic_next'
collect2: error: ld returned 1 exit status
CMakeFiles/Makefile2:7914: recipe for target 'source/creator/CMakeFiles/blender.dir/all' failed
It seems to be related to OpenMP. I installed libomp-dev
in course of previous clang
attempts, but now I will try once again without it.
UPDATE I can happily report that the compilation works now. Here is the script assuming 18.04 with CUDA already installed:
sudo apt-get -qq update && sudo add-apt-repository -y ppa:ubuntu-toolchain-r/test
sudo apt-get -qq update && sudo apt-get install -y build-essential git subversion cmake libx11-dev libxxf86vm-dev libxcursor-dev libxi-dev libxrandr-dev libxinerama-dev libglew-dev gcc-9 g++-9 software-properties-common && sudo apt autoremove -y
git clone https://git.blender.org/blender.git
mkdir -p lib && cd lib && svn checkout --quiet https://svn.blender.org/svnroot/bf-blender/trunk/lib/linux_centos7_x86_64
sudo apt install -y gcc-8 g++-8
ln -sf /usr/bin/gcc-8 /usr/local/cuda/bin/gcc && ln -sf /usr/bin/g++-8 /usr/local/cuda/bin/g++
cd blender && make update
CC=gcc-9 CXX=g++-9 make #with whatever arguments
For those having problems with GCC version on Ubuntu 18.04:
GCC version must be at least 9.3 for precompiled libraries, found 7.5.0
