Blender 2.8 - Panel Location
Well, for starters you selected “scene” and not “render” in the Properties. If you tested the Simple Panel example, you will see it adds the “label” ,but not the other properties. I think this is because you might have to have your properties be the same context as the bl_context. I might be completely wrong about this.
