I wrote a python helper script a few years ago to do exactly this for a compositor node, you could probably do something similar for cycles. I’ll post the code incase you want to re-use it
import sys
import os
import re
# Following the instructions from https://wiki.blender.org/index.php/User:Sobotka/Minimal_Node_Code
def SourcePath(SourceFolder, path):
return os.path.join(SourceFolder,path)
def ValidNode(source, node):
print("Step 0: Determine if node already exists")
sp = SourcePath(source,"source/blender/blenkernel/BKE_node.h")
nodeline = "#define CMP_NODE_{}".format(node.upper())
f = open(sp, "r")
contents = f.readlines()
f.close()
lines = len(contents)
index = -1
for x in range(0, lines):
if nodeline in contents[x]:
return False
return True
def step1_updatebkenode(source, node):
print("Step 1: Register the Unique Node ID Value in source/blender/blenkernel/BKE_node.h")
f = open(sp, "r")
f.close()
index = -1
if "#define CMP_NODE_" in contents[x]:
index = x
tokens = contents[index].split()
lastid = tokens[len(tokens)-1]
newid = int(lastid)+1
newline = "#define CMP_NODE_{}\t{}\n".format(node.upper(), newid)
contents.insert(index+1, newline)
f = open(sp, "w")
contents = "".join(contents)
f.write(contents)
f.close()
def step2_updatenodec(source, node):
print("Step 2: Register the new node in source/blender/blenkernel/intern/node.c")
sp = SourcePath(source,"source/blender/blenkernel/intern/node.c")
f = open(sp, "r")
f.close()
index = -1
if "register_node_type_cmp_" in contents[x]:
index = x
newline = "\tregister_node_type_cmp_{}();\n".format(node.lower())
f = open(sp, "w")
f.write(contents)
f.close()
def step3_updatedna(source, node):
print("Step 3: Add the DNA that describes the data in source/blender/makesdna/DNA_node_types.h")
sp = SourcePath(source,"source/blender/makesdna/DNA_node_types.h")
f = open(sp, "r")
f.close()
index = -1
if "/* script node mode */" in contents[x]:
index = x
newline = "typedef struct Node{} {{\n\tdouble {}Double; /* Our {} data. */\n}} Node{};\n\n".format(node,node,node,node)
contents.insert(index, newline)
f = open(sp, "w")
f.write(contents)
f.close()
def step4_registerrna(source, node):
print("Step 4: Register the Python RNA in source/blender/makesrna/intern/rna_nodetree.c")
sp = SourcePath(source,"source/blender/makesrna/intern/rna_nodetree.c")
f = open(sp, "r")
f.close()
index = -1
if "/* -- Texture Nodes --------------------------------------------------------- */" in contents[x]:
index = x
newline = "static void def_cmp_{}(StructRNA *srna)\n{{\n}}\n".format(node.lower())
f = open(sp, "w")
f.write(contents)
f.close()
def step5_registerstatictypes(source, node):
print("Step 5: Register the node in Python RNA in /source/blender/nodes/NOD_static_types.h")
sp = SourcePath(source,"source/blender/nodes/NOD_static_types.h")
f = open(sp, "r")
f.close()
index = -1
if "DefNode( CompositorNode, CMP_NODE_" in contents[x]:
index = x
newline = "DefNode( CompositorNode, CMP_NODE_{},".format(node.upper())
newline = newline.ljust(50)
newline = "{}def_cmp_{},".format(newline,node.lower())
newline = newline.ljust(74)
newline = "{}\"{}\",".format(newline,node.upper())
newline = newline.ljust(92)
newline = "{}{},".format(newline,node)
newline = newline.ljust(110)
newline = "{}\"{}\",".format(newline,re.sub(r'([a-z](?=[A-Z])|[A-Z](?=[A-Z][a-z]))', r'\1 ', node))
newline = newline.ljust(131)
newline = newline+"\"\" )\n"
f = open(sp, "w")
f.write(contents)
f.close()
def step6_registernodcomposite(source, node):
print("Step 5: Register the node in source/blender/nodes/NOD_composite.h")
sp = SourcePath(source,"source/blender/nodes/NOD_composite.h")
f = open(sp, "r")
f.close()
index = -1
if "void register_node_type_cmp_" in contents[x]:
index = x
newline = "void register_node_type_cmp_{}(void);\n".format(node.lower())
f = open(sp, "w")
f.write(contents)
f.close()
def step7_createnode(source, node):
fn = "source/blender/nodes/composite/nodes/node_composite_{}.c".format(node.lower())
print("Step 7: Create a new file that defines node inputs and output in %s" % (fn))
sp = SourcePath(source,fn)
contents = """#include "node_composite_util.h"
/* **************** TKNSPACED Tool ******************** */
static bNodeSocketTemplate cmp_node_TKNLOWER_in[]= {
{ SOCK_RGBA, 1, N_("Image"), 1.0f, 1.0f, 1.0f, 1.0f},
{ SOCK_FLOAT, 1, N_("Variable"), 1.0f, 0.0f, 0.0f, 0.0f, 0.001f, 10.0f, PROP_UNSIGNED},
{ -1, 0, "" }
static bNodeSocketTemplate cmp_node_TKNLOWER_out[]= {
{ SOCK_RGBA, 0, N_("Image")},
{ -1, 0, "" }
void register_node_type_cmp_TKNLOWER(void)
static bNodeType ntype;
node_type_base(&ntype, CMP_NODE_TKNUPPER, "TKNSPACED", NODE_CLASS_CONVERTOR, NODE_OPTIONS);
node_type_socket_templates(&ntype, cmp_node_TKNLOWER_in, cmp_node_TKNLOWER_out);
node_type_size(&ntype, 140, 100, 320);
nodeRegisterType(&ntype);
contents = contents.replace("TKNLOWER", node.lower())
contents = contents.replace("TKNUPPER", node.upper())
contents = contents.replace("TKNSPACED", re.sub(r'([a-z](?=[A-Z])|[A-Z](?=[A-Z][a-z]))', r'\1 ', node))
f = open(sp, "w")
f.write(contents)
f.close()
def step8_updatecmakelists(source, node):
print("Step 8: Make sure it is compiled by adding it to source/blender/nodes/CMakeLists.txt")
sp = SourcePath(source,"source/blender/nodes/CMakeLists.txt")
f = open(sp, "r")
f.close()
index = -1
if "composite/nodes/node_composite_" in contents[x]:
index = x
newline = "\tcomposite/nodes/node_composite_{}.c\n".format(node.lower())
f = open(sp, "w")
f.write(contents)
f.close()
def step9_createnodeheader(source, node):
fn = "source/blender/compositor/nodes/COM_{}Node.h".format(node)
print("Step 9: Create the header file for the node in %s" % (fn))
contents = """#ifndef _COM_TKNNORMALNode_h_
#define _COM_TKNNORMALNode_h_
#include "COM_Node.h"
* @brief TKNNORMALNode
* @ingroup Node
class TKNNORMALNode : public Node {
public:
TKNNORMALNode(bNode *editorNode);
void convertToOperations(NodeConverter &converter, const CompositorContext &context) const;
#endif"""
contents = contents.replace("TKNNORMAL", node)
f = open(sp, "w")
f.write(contents)
f.close()
def step10_createnode(source, node):
fn = "source/blender/compositor/nodes/COM_{}Node.cpp".format(node)
print("Step 10: Create the main node file in %s" % (fn))
contents = """#include "COM_TKNNORMALNode.h"
#include "COM_TKNNORMALOperation.h"
#include "COM_ExecutionSystem.h"
TKNNORMALNode::TKNNORMALNode(bNode *editorNode) : Node(editorNode)
/* pass */
void TKNNORMALNode::convertToOperations(NodeConverter &converter, const CompositorContext &context) const
TKNNORMALOperation *operation = new TKNNORMALOperation();
converter.mapInputSocket(getInputSocket(0), operation->getInputSocket(0));
converter.mapInputSocket(getInputSocket(1), operation->getInputSocket(1));
converter.mapOutputSocket(getOutputSocket(0), operation->getOutputSocket(0));
converter.addOperation(operation);
f = open(sp, "w")
f.write(contents)
f.close()
def step11_createoperationheader(source, node):
fn = "source/blender/compositor/operations/COM_{}Operation.h".format(node)
print("Step 11: Write the header file for the operation in %s" % (fn))
contents = """#ifndef _COM_TKNNORMALOperation_h
#define _COM_TKNNORMALOperation_h
#include "COM_NodeOperation.h"
class TKNNORMALOperation : public NodeOperation {
private:
* Cached reference to the inputProgram
SocketReader *m_inputProgram;
SocketReader *m_inputTKNNORMALProgram;
public:
* the inner loop of this program
void executePixelSampled(float output[4], float x, float y, PixelSampler sampler);
* Initialize the execution
void initExecution();
* Deinitialize the execution
void deinitExecution();
#endif"""
f = open(sp, "w")
f.write(contents)
f.close()
def step12_createoperation(source, node):
fn = "source/blender/compositor/operations/COM_{}Operation.cpp".format(node)
print("Step 12: Create the code that does the work in %s" % (fn))
contents = """#include "COM_TKNNORMALOperation.h"
#include "BLI_math.h"
TKNNORMALOperation::TKNNORMALOperation() : NodeOperation()
this->addInputSocket(COM_DT_COLOR);
this->addInputSocket(COM_DT_VALUE);
this->addOutputSocket(COM_DT_COLOR);
this->m_inputProgram = NULL;
this->m_inputTKNNORMALProgram = NULL;
void TKNNORMALOperation::initExecution()
this->m_inputProgram = this->getInputSocketReader(0);
this->m_inputTKNNORMALProgram = this->getInputSocketReader(1);
void TKNNORMALOperation::executePixelSampled(float output[4], float x, float y, PixelSampler sampler)
float inputValue[4];
float inputTKNNORMAL[4];
this->m_inputProgram->readSampled(inputValue, x, y, sampler);
this->m_inputTKNNORMALProgram->readSampled(inputTKNNORMAL, x, y, sampler);
const float TKNLOWER = inputTKNNORMAL[0];
/* check for negative to avoid nan's */
output[0] = inputValue[0] > 0.0f ? powf(inputValue[0], TKNLOWER) : inputValue[0];
output[1] = inputValue[1] > 0.0f ? powf(inputValue[1], TKNLOWER) : inputValue[1];
output[2] = inputValue[2] > 0.0f ? powf(inputValue[2], TKNLOWER) : inputValue[2];
output[3] = inputValue[3];
void TKNNORMALOperation::deinitExecution()
f = open(sp, "w")
f.write(contents)
f.close()
def step13_updatenodeconvert(source, node):
print("Step 13: Add the node to the converter code listing in source/blender/compositor/intern/COM_Converter.cpp")
sp = SourcePath(source,"source/blender/compositor/intern/COM_Converter.cpp")
f = open(sp, "r")
f.close()
index = -1
lastinclude=-1
if "/* not inplemented yet */" in contents[x]:
index = x
if "#include \"COM_" in contents[x]:
lastinclude = x
newline = "\t\tcase CMP_NODE_{}:\n\t\t\tnode = new {}Node(b_node);\n\t\t\tbreak;\n".format(node.upper(),node)
newline = "#include \"COM_{}Node.h\"\n".format(node)
contents.insert(lastinclude+1, newline)
f = open(sp, "w")
f.write(contents)
f.close()
def step14_updatecmakelists(source, node):
print("Step 14: Make sure it will get compiled via cmake in source/blender/compositor/CMakeLists.txt")
sp = SourcePath(source,"source/blender/compositor/CMakeLists.txt")
f = open(sp, "r")
f.close()
index = -1
if "\toperations/COM_" in contents[x]:
index = x
newline = "\n\t# TKNNORMAL Nodes\n\tnodes/COM_TKNNORMALNode.cpp\n\tnodes/COM_TKNNORMALNode.h\n\toperations/COM_TKNNORMALOperation.h\n\toperations/COM_TKNNORMALOperation.cpp\n"
newline = newline.replace("TKNNORMAL", node)
f = open(sp, "w")
f.write(contents)
f.close()
def step15_nodeitems(source, node):
print("Step 15: And finally add it to release/scripts/startup/nodeitems_builtins.py so it will show up in the UI")
sp = SourcePath(source,"release/scripts/startup/nodeitems_builtins.py")
f = open(sp, "r")
f.close()
index = -1
if "CompositorNodeCategory(\"CMP_CONVERTOR\", \"Converter\", items=[" in contents[x]:
index = x
newline = " NodeItem(\"CompositorNodeTKNNORMAL\"),\n"
f = open(sp, "w")
f.write(contents)
f.close()
def main(argv):
print("Blender folder = %s" % (argv[1]))
print("NodeName = %s" % (argv[2]))
print("")
if ValidNode(argv[1], argv[2]):
step1_updatebkenode(argv[1], argv[2])
step2_updatenodec(argv[1], argv[2])
step3_updatedna(argv[1], argv[2])
step4_registerrna(argv[1], argv[2])
step5_registerstatictypes(argv[1], argv[2])
step6_registernodcomposite(argv[1], argv[2])
step7_createnode(argv[1], argv[2])
step8_updatecmakelists(argv[1], argv[2])
step9_createnodeheader(argv[1], argv[2])
step10_createnode(argv[1], argv[2])
step11_createoperationheader(argv[1], argv[2])
step12_createoperation(argv[1], argv[2])
step13_updatenodeconvert(argv[1], argv[2])
step14_updatecmakelists(argv[1], argv[2])
step15_nodeitems(argv[1], argv[2])
else:
print("Node Already Exists, exiting...")
pass
if __name__ == "__main__":
main(sys.argv)
disclaimer: it was written in oct 2017 and may not work properly on the current code-base
