I wanted to work on some old fps projects but then noticed the script does not work anymore in 2.8
Anyone here kind enough to port it?
Looks like someone made a port to support 2.80 see if it works for you.
ye thanks alot : ) i got it working.
https://github.com/DarklightGames/io_export_ase/archive/2.80.zip
I couldn’t get it to work automatically, if it doesn’t work for you try renaming the folder manually: io_export_ase-2.80 to io_export_ase
after that add-on search “asci” and turn it on.
That’s great! I was just going to tell you to try renaming the folder.
