For reference, here’s an example script:
# Example of creating a polygonal mesh in Python from numpy arrays
# Note: this is Python 3.x code
# $ blender -P create_mesh.py
# See this link for more information on this part of the API:
# https://docs.blender.org/api/blender2.8/bpy.types.Mesh.html
# Paul Melis (paul.melis@surfsara.nl), SURFsara, 24-05-2019
import bpy
import numpy
# Note: we DELETE all objects in the scene and only then create the new mesh!
bpy.ops.object.select_all(action='SELECT')
bpy.ops.object.delete()
# Vertices and edges (straightforward)
vertices = numpy.array([
0, 0, 0,
2, 0, 0,
2, 2, 0.2,
0, 2, 0.2,
1, 3, 1,
1, -1, -1,
0, -2, -1,
2, -2, -1
], dtype=numpy.float32)
# Setting edges is optional, as they get created automatically for
# any provided polygons. However, if you need edges that exist separately
# from polygons then use this array.
# XXX these edges only seem to show up after going in-and-out of edit mode.
edges = numpy.array([
5, 6,
6, 7,
5, 7
], dtype=numpy.int32)
num_vertices = vertices.shape[0] // 3
num_edges = edges.shape[0] // 2
# Polygons are defined in loops. Here, we define one quad and two triangles
vertex_index = numpy.array([
0, 1, 2, 3,
4, 3, 2,
0, 5, 1
# For each polygon the start of its vertex indices in the vertex_index array
loop_start = numpy.array([
0, 4, 7
# Length of each polygon in number of vertices
loop_total = numpy.array([
4, 3, 3
num_vertex_indices = vertex_index.shape[0]
num_loops = loop_start.shape[0]
# Texture coordinates per vertex *per polygon loop*.
uv_coordinates = numpy.array([
0, 0,
1, 0,
1, 1,
0, 1,
0.5, 1,
0, 0,
1, 0,
0, 1,
0.5, 0,
1, 1
# Vertex color per vertex *per polygon loop*
vertex_colors = numpy.array([
1, 0, 0,
1, 0, 0,
1, 0, 0,
1, 0, 0,
0, 1, 0,
0, 1, 0,
0, 1, 0,
1, 0, 0,
0, 1, 0,
0, 0, 1
assert uv_coordinates.shape[0] == 2*vertex_index.shape[0]
assert vertex_colors.shape[0] == 3*vertex_index.shape[0]
# Create mesh object based on the arrays above
mesh = bpy.data.meshes.new(name='created mesh')
mesh.vertices.add(num_vertices)
mesh.vertices.foreach_set("co", vertices)
mesh.edges.add(num_edges)
mesh.edges.foreach_set("vertices", edges)
mesh.loops.add(num_vertex_indices)
mesh.loops.foreach_set("vertex_index", vertex_index)
mesh.polygons.add(num_loops)
mesh.polygons.foreach_set("loop_start", loop_start)
mesh.polygons.foreach_set("loop_total", loop_total)
# Create UV coordinate layer and set values
uv_layer = mesh.uv_layers.new()
for i, uv in enumerate(uv_layer.data):
uv.uv = uv_coordinates[2*i:2*i+2]
# Create vertex color layer and set values
vcol_lay = mesh.vertex_colors.new()
for i, col in enumerate(vcol_lay.data):
col.color[0] = vertex_colors[3*i+0]
col.color[1] = vertex_colors[3*i+1]
col.color[2] = vertex_colors[3*i+2]
col.color[3] = 1.0 # Alpha?
# We're done setting up the mesh values, update mesh object and
# let Blender do some checks on it
mesh.update()
mesh.validate()
# Create Object whose Object Data is our new mesh
obj = bpy.data.objects.new('created object', mesh)
# Add *Object* to the scene, not the mesh
scene = bpy.context.scene
scene.collection.objects.link(obj)
# Select the new object and make it active
bpy.ops.object.select_all(action='DESELECT')
obj.select_set(True)
bpy.context.view_layer.objects.active = obj
