hey everyone,
when I make my own widgets with custom shape gizmos, I find that the area and position where the widget is “activated” (ready to be used) to be very small: I can move the cursor over large parts of the shape without activation. This area also seems to move depending on the view and is not working at all in orthographic view along the axes.
The blender widgets don’t have this problem. Is there an option I missed to activate, or something.
already thanks for having a look.
Here is my example code (I made it as addon, because I have problems starting gizmos scripts within blender text editor):
import bpy
from mathutils import Vector
from bpy.types import (
Gizmo,
GizmoGroup,
bl_info = {
"name": "WidgetTester",
"author": "Modicolitor",
"version": (0, 1),
"blender": (2, 83, 0),
"location": "View3D > Tools",
"description": "Test your widget shapes",
"category": "Object"}
class BE_GizmoGroup(GizmoGroup):
bl_idname = "OBJECT_GGT_PLANARCONNECTOR"
bl_label = "Positioning GizmoGroup"
bl_space_type = 'VIEW_3D'
bl_region_type = 'WINDOW'
bl_options = {'3D', 'PERSISTENT'}
@classmethod
def poll(cls, context):
ob = context.object
return ob != None
def setup(self, context):
ob = context.object
centerR = self.gizmos.new(CenterShapeWidget.bl_idname)
props = centerR.target_set_operator("object.ot_scalemini")
centerR.matrix_basis = ob.matrix_world.normalized()
centerR.use_draw_offset_scale = True
centerR.matrix_offset[0][3] = -2
centerR.matrix_offset[1][3] = 2
centerR.matrix_offset[2][3] = 2
centerR.color = 0.05, 0.2, 0.8
self.WidCR = centerR
centerL = self.gizmos.new(CenterShapeWidget.bl_idname)
props = centerL.target_set_operator("object.ot_scalemini")
centerL.use_draw_offset_scale = True
centerL.matrix_basis = ob.matrix_world.normalized()
centerL.matrix_offset[0][3] = -2 # moving the centered Gizmoshape
centerL.matrix_offset[1][3] = -2
centerL.matrix_offset[2][3] = 2
centerL.color = 0.05, 0.2, 0.8
self.WidCL = centerL
def refresh(self, context):
ob = context.object
centerR = self.WidCR
centerL = self.WidCL
# centered
centered0 = Vector((0.0, 1.0, -1.0))
centered1 = Vector((0.866, -0.50, -1.0))
centered2 = Vector((-0.866, -0.50, -1.0))
centered3 = Vector((0.0, 0.0, 1.0))
center_shape = (
centered0, centered1, centered2,
centered0, centered1, centered3,
centered2, centered1, centered3,
centered0, centered2, centered3,
class CenterShapeWidget(Gizmo):
bl_idname = "VIEW3D_GT_CENTERSHAPE"
def draw(self, context):
self.draw_custom_shape(self.custom_shape)
def draw_select(self, context, select_id):
self.draw_custom_shape(self.custom_shape, select_id=select_id)
def setup(self):
if not hasattr(self, "custom_shape"):
self.custom_shape = self.new_custom_shape(
'TRIS', center_shape)
class BE_OT_scale(bpy.types.Operator):
bl_idname = "object.ot_scalemini"
bl_label = "BE_PP_scalemini"
@classmethod
ob = context.object
return ob != None
def execute(self, context):
ob = context.object
ob.scale.x = self.value
return {'FINISHED'}
def modal(self, context, event):
if event.type == 'MOUSEMOVE': # Apply
self.delta = event.mouse_x - self.init_value
self.value = self.init_position + self.delta / 1000
self.execute(context)
elif event.type == 'LEFTMOUSE': # Confirm
return {'FINISHED'}
elif event.type in {'RIGHTMOUSE', 'ESC'}: # Cancels
ob.scale.x = self.init_value
return {'CANCELLED'}
return {'RUNNING_MODAL'}
ob = context.object
self.init_position = ob.scale.x
self.init_value = event.mouse_x
self.value = ob.scale.x
context.window_manager.modal_handler_add(self)
classes = (
BE_GizmoGroup,
CenterShapeWidget,
BE_OT_scale,
register, unregister = bpy.utils.register_classes_factory(classes)
