I have designed a model like this. I have NOT created any UV map.
I want to export it as FBX. When I do so, as I don’t have UVs, the Base Color texture (Diffuse Texture) is not displayed. So, I want to generate the UV map for base color texture. I can create a new UV Map, do UV Unwrap and bake a DIFFUSE texture but, my requirement is,
This FBX will be imported into an online viewer. In that viewer, a user can upload his own image and that image should be applied and shown. So, If my UV Map is a atlas-packed, it won’t work.
So, basically, I need to figure-out how the Blender/Cycles calculate UV from the GENERATED attribute. Where is this logic/code located?
Thanks in advance
Implemented like this but the quality is not good. Do I need to do anything?
const char *attrib_name = uv_attribute_name ? uv_attribute_name : "_dnt_generated_diffuse_uv_";
ustring attribute_name(attrib_name);
Attribute *uvs_attribute = mesh.attributes.find(attribute_name);
if (!uvs_attribute) {
uvs_attribute = mesh.attributes.add(AttributeStandard::ATTR_STD_UV, attribute_name);
float2 *uv_data = uvs_attribute->data_float2();
int vertices_count = mesh.verts.size();
MinAndMax3 minmax;
for (int i = 0; i < vertices_count; i++) {
minmax.AddPoint(mesh.verts[i]);
float3 &loc = minmax.GetCenter();
float3 &size = minmax.GetSize();
if (size.x != 0.0f)
size.x = 0.5f / size.x;
if (size.y != 0.0f)
size.y = 0.5f / size.y;
if (size.z != 0.0f)
size.z = 0.5f / size.z;
loc = loc * size - make_float3(0.5f, 0.5f, 0.5f);
float3 *generated_data = new float3[vertices_count];
float3 &vertex = mesh.verts[i];
generated_data[i] = (vertex * size) - loc;
int indices_count = mesh.triangles.size();
for (int i = 0; i < indices_count; i++) {
int vertex_index = mesh.triangles[i];
const float3 orco = (generated_data[vertex_index] + loc) / size;
// const float2 tmp = map_to_sphere(orco);
uv_data[i] = map_to_sphere(orco);
delete[] generated_data;
