Check the overview thread for more information about the meeting.
Present
- Cartesian Caramel
- Dalai Felinto
- Habib Gahbiche
- Hans Goudey
- Jacques Lucke
- Lukas Tönne
- Simon Thommes
Since the Last Meeting
- Blog Post: Declarative Systems in Geometry Nodes
- Switch Nodes:
- Warnings:
- Frames:
- File Import:
- Search:
- Support searching for math operations and color blend modes in Add menu (math operations, blend modes)
- Support searching for dynamic node labels (commit)
- Devtalk Proposals:
- New operator to add new empty node group (commit)
- Allow dragging Group Inputs from panel into node editor (commit)
- New Grid Info node (commit)
Meeting Topics
- Bit Math node
- Eventually we might need to specify the integer bit width in the node.
- It would be great if the PR included a use case.
- The operation label could use the “Bitwise” word too, to further separate the results in search and make the difference with the boolean math node clearer.
- (e.g., Bitwise Or)
- Don’t jump viewer node if it’s still visible
- A heuristic for moving the viewer node to the right if it’s far to the left of the viewed node might be helpful in practice. Simon will test that.
- Auto-hide unused inputs if usage depends on menu
- Support separators in node group interface
- We’ll get Pablo’s opinion on this too, just to make sure it isn’t breaking UI conventions.
- Move spreadsheet context path to side bar
- Generally good.
- The “viewer/original/evaluated” drop down could be above the object name.
- The “Context” panel name can become the object name with the icon with the dropdown enum name in parentheses.
- Simplify adding named frames
- The operator should be in the context menu.
- Allow detaching frame while dragging node
- The operator currently mapped to “F” moves to “J”.
- The order of pressing “G” and “F” is important. In reverse it creates a frame named “G” instead.
- Simon will try it.
- Fix #138388: Use grid voxel corners as value locations like OpenVDB
- Lukas worked on a fix to this long-standing issue.
- Mesh: Rewrite face corner normals calculation
- Hans is looking to land this and searching for a green checkmark.
