Date/Time: 2025-02-17T15:00:00Z
Link: https://meet.google.com/xxo-tyin-rem
Attendees:
- Antonio Vazquez (Developer)
- Casey Bianco-Davis (Developer)
- Daniel Martinez Lara (Grease Pencil team)
- Falk David (Blender)
- Friedrich Schäper (Grease Pencil User, Studio Huckepack)
- Samuel Bernou (Python Dev, ADV studio)
Topics
- General updates
- Discussions
Meeting Notes
- General updates:
- Blender 4.4 is in Beta. Please test it out, and if you find issues, please report them. Thank you!
- Falk: Will be focusing on the “VSE Story project” (design task) the next week or two. Will still be available for review/questions etc.
- Development updates:
- Most of the work was going into fixing high severity issues for 4.4.
- 24 bug fixes committed since last meeting.
- Hidden layers are no longer part of evaluated data.
- New features for 4.5 LTS:
- Options in the layers “Extras” menu to mask layer above or below the active layer (see release notes for more details)
- Python API: Layers and layer groups are now part of the same base class
GreasePencilTreeNode
and share common properties. The tree node has two new propertiesnext_node
andprev_node
to access nodes above and below (at the same level).
Show all commits
- Fix: Grease Pencil: Debug build error when armature is parent by Pratik Borhade
- Fix #134003: Grease Pencil: Deleting vgroup shifts other vgroup content by Pratik Borhade
- Fix: Geometry Nodes: Instance on Points ignores Grease Pencil layer transform by Jacques Lucke
- Fix #134159: Grease Pencil: Use “Blank” for the entry name in add menu by YimingWu
- Fix #134035: Grease Pencil: Correct index for multistroke modifier by YimingWu
- Fix #134166: Show Context Menus as “Options” on Status Bar by Harley Acheson
- Fix #134152: Grease Pencil: Keyframe color missing in viewport text overlays by Pratik Borhade
- Fix: Grease Pencil: Use
ensure_selection_attribute
invgroup_select_verts
by Falk David - Fix: Grease Pencil: Missing operator to delete breakdown keyframes by Pratik Borhade
- Fix #132826: Grease Pencil: Missing “Paste by Layer” option by Falk David
- Fix #134284: Grease Pencil: Build modifier natural drawing speed fails by Pratik Borhade
- Fix #134309: Grease Pencil: SVG export crashes on constructive modifiers by Lukas Tönne
- Fix #134289: Grease Pencil: SVG export crashes with no material by YimingWu
- Fix unreported: Grease Pencil “Add Masking Layer” operators duplicate check always returned nullptr by Janne Nylander
- Grease Pencil: Python: Add base class for layer and layer groups by Falk David
next/prev_node
toGreasePencilTreeNode
by Falk David - Fix: Grease Pencil: Mask icon for layer groups is not correct by Falk David
- Grease Pencil: Merge GPENCIL_PrivateData into GPENCIL_Instance by Clément Foucault
- Fix: Grease Pencil: Remove invisible layers from evaluated data by Falk David
- Fix #134395: “Intersect” selection mode not working for Grease Pencil by Philipp Oeser
- Fix #134362: Grease Pencil canvas settings don’t do anything by Pratik Borhade
- Fix #134468: Grease Pencil: Primtive tools considering mouse drag threshold by Pratik Borhade
- Grease Pencil: Add python operator for masking with above/below layer by Janne Nylander
- Fix #134482: Grease Pencil: Correct mask for stroke interpolation by YimingWu
- Fix #133339: Grease Pencil: Ensure span attribute writers are valid by Falk David
- Fix: Grease Pencil: Points copied from same stroke were not split by Falk David
- Fix error in grease_pencil.relative_layer_mask_add poll by Campbell Barton
- Discussion: Pinned materials in brush assets are currently broken (see #131186 and #134268)
- Two proposed solutions:
- Lookup for local material with same name, add local copy of brush material if none found. Problem: If there is an existing material with the same name as the pinned material in the brush asset, the wrong material will get used.
- “Append & reuse” approach. Problem: Will likely result in duplicate materials.
- Casey: Can see that users often use pinned materials with generic names like “Material”, so it seems better to end up with duplicate materials.
- Antonio: If embedded assets are expected to come this year, it seems better to have duplicate materials rather than the wrong material for a brush asset.
- Falk: Worked on a proposal on how to get the “Bake Mesh Animation” functionality back.
- Bake evaluated to original" Grease Pencil operator #134670
- To bake all the modifiers on a Grease Pencil object to range of frames
- Mesh to Curve: Option to turn faces into curves #134671
- To turn faces into Grease Pencil strokes.
- Feedback on this idea was positive.
- Daniel: Hidden layers are no longer part of evaluated data, but what about hidden materials?
- Falk: We could potentially remove strokes with a hidden material in the evaluation step. Seems reasonable.
- Daniel: What’s the process for getting new default brushes into Blender?
- Falk: Thinks it would be best to open a new feedback thread on devtalk.blender.org and gather some nice defaults. Then we can upload them to the essential library. The brushes are part of a
.blend
file here: blender-assets/brushes at main - blender-assets - Blender Projects.
- Friedrich: Is there a chance we can get materials with image sequence to pull the textures from?
- Daniel: Thinks that a lot of effects can be done with Geometry Nodes in the future.
- Falk: Technically this could be implemented into Grease Pencil materials, but it’s unclear whether or not these will stay. There are some ideas to revamp the rendering side of Grease Pencil and integrate it more into EEVEE.
- Casey: There’s an issue with the way the current hole design works. Because a hole in a shape will cut away into anything else in that shape, you can’t have islands inside a hole as part of the same shape.
- Casey: One idea could be to make it so that holes only cut into strokes that come after it.
- Falk: Will have to think more about this. Maybe this is just a limitation we have to accept. Will get back to Casey.
- Friedrich: The lasso erase seems to do what the trim tool does, but not erase individual points.
- Falk: Will check if the lasso erase is doing what it is supposed to do.
- EDIT: Seems like there is a Ctrl+LMB shortcut that doesn’t do the same as CTRL+Alt+LMB (which is the lasso eraser). Might be a bug in the keymap.
- Friedrich: Missing the boundary strokes to easily create closed areas.
- Falk: Was removed in 4.3 because it was too tricky to port this. Will look into finding a solution to implement this in GPv3.
Next Meeting
- Time/Date: 2025-03-03T15:00:00Z
