Eventually it will, but not clear when.
Will this be available via the Buildbot eventually?
I tried building it yesterday on Linux, succeeded in compiling USD from source but building the Hydra delegate stopped at one point. As Iâm not a coder or experienced builder I gave up.
Thereâs no specific plan for that at the moment. A problem is that every application requires a different build due to different USD and other library versions, and we donât have the time to support that kind of thing.
I understand, thanks for the info.
Some minutes ago I managed to compile the RadeonProRenderUSD Hydra delegate from source by simply following the documentation on their site https://github.com/GPUOpen-LibrariesAndSDKs/RadeonProRenderUSD
It was quite simple and I could build it against an install of Houdini without the need for a separate USD version on my system. If the Cycles delegate would be as easy to build I guess many users could build it themselves.
I have a suggestion that (sadly) involves big changes: make âWorldâ a light object in the scene, instead of a scene property.
The difference here is that the RPR binary libs are pre-built for you⌠If the cycles libs were prebuilt on build bot it would probably be just as easy.
I thought the RPR binaries are pre-built by necessity as it is closed source? If source is available that would be great for community debugging of issues in RPR USD/Hydra or the Blender RPR plugin!
The source of the plugins and USD Hydra delegate is available, but the render is binary only.
The point to this discussion is that it might make sense for Blender to provide Cycles dll / .so for purposes of the Hydra delegate. However if itâs using versions of TBB or OpenVDB libraries that are not compatible with say Houdini the DLL might cause symbol issues. (This was the whole point of the VFX platform).
Users could set multiple âworldsâ at wish, play with their ray-visibility, rotate-move-scale, animate, copy-paste, etcâŚ
TBH having the world as an object could be a thing, but we can have many worlds having just one world property, as long as you use Light Gropus you should be able to define many outputs, at least theoretically, and mark one as the main one, that is automatically composed, and the other ones would yo to their LG.
Check the Lg dev notes and future improvements, this is in the least as a possible improvement
Some steps towards getting this building for Houdini here, but itâs not actually working yet.
https://developer.blender.org/D14594
I 100% agree. I have never understand why the world is not a light object (or at least why there isnât a dome type of light object anymore), because in production (we work with maya at the studio) we always rely on different dome lights with tweaked visibilities/intensities combined with light linkingâŚe.g., we use more than one dome, one is only for speculars, one for hair, etcâŚso we can have a lot of control over certain aspects of the rendering output without having to separate those in different layers/scenes
Never used Maya, and actually world as a scene property has grown on me as a second nature. But once I started messing with unreal, the concept of world=lamp opened my eyes
Does the Intel OneAPI use Open CL and if yes could it be used to support AMD GPUs in blender.
There are several things here:
1.- Light Linking: not there yet
2.- Light Path: you can already use light path and have different environment for every light path
3.- Multiple worlds illuminating: thatâs what Lukas has in his list, multiple worlds as light groups
Si the thing of it being an object or not is totally secondary, the important thing here is to have several environments available in different ways but no need for it to be an object
I remember correctly vegaâs hip has been submitted
AMD only supports the newer cards right now and some cards on Linux. Considering Apple added RX 580 support and Metal outperforms HIP !!?? Intelâs OneAPI support would be a god send for older AMD GPU users.
OneAPI will not work for AMD GPUs, and weâre not using OpenCL.
Thanks. I probably misunderstood what I read on the Intel site. Thatâs sad news for older AMD GPU users though.
I agree that world HDRi as âlightsâ is way better. And it also makes more sense since you can easily rotate a âWorld Light / 360 Lightâ
