Info
Developers or artists interested in contributing are welcome to join at the links below.
- Workboard - plans, ongoing work, and community tasks
- Chat Channel - general development communication
- Video Call - dailies at 14:00 CEST
- Meeting Agendas and Notes - updated throughout the week
Week starting 2021-10-18
random_id
implementation.- Should it be another attribute provider implementation, or modify the existing builtin custom data provider?
- The latter was decided upon.
- Create task for nodes that we want to rename later (verb first naming).
- “String Replace” name
Replace Substring
Replace String
Week starting 2021-10-25
- Product demo.
- [x] T91783: Sort children in Collection Info node
- Look into not adding “Realized geometry is not used when pick instances is true” multiple times.
- [x] T91890: Make outputing an instance in the object info node optional
- [x] T91763: Updated version of subdivision surface node
Consider removing the enum labels. (Hans)Consider renaming Geometry sockets. (Hans)
- [x] T91651: Updated Attribute Transfer Node
- [x] T91542: Node menu cleanup for fields
Menus are broken when there is no node tree. (Jacques)
- [x] T91754: Don’t realize instances when there are other modifiers by default
- Show warning in modifier when they can’t process the geometry.
- [x] T92326: Updated version of raycast node
Change direction default to (0, 0, -1). (Jacques)
- [x] T91884: Add warnings for nodes that don’t work with instances
- [x] T91486: Attribute Search in modifier
Fix typing “new” attributes for input attributes. (Hans)
- [x] T91485: Input Attribute Toggle on left side in modifier
- [x] T92157: Update bounding box node to work with instances
- [x] T91762: Updated versions of curve to points and curve endpoints nodes
- [x] T92005: Make “Stable ID” a built-in attribute
Column width for id attribute in spreadsheet (Jacques)Use “id” instead of “ID” as column name for instances. (Jacques)
- [x] T91744: Disable attribute search for non-attribute string sockets
- [x] T91934: Add “Fill Caps” option to the curve to mesh node
- [x] T92216: Add an “Instances to Points” Node
Incorrect warning in Instances to Points node. (Jacques)
- [x] T91847: Image Texture node
- [x] T92167: Add field input to viewer node for spreadsheet visualization
- Find viewer node when opening new spreadsheet.
- [x] T92168: Update volume to mesh node to remove grid name
- [x] T91881: Remove reference to “Anonymous Attribute” in socket inspection
- [x] T83109: Implement breadcrumbs for node editor
- [x] T92413: Only create instance ids when points have ids in the Instance on Points node
- [x] T92425: ID attribute get and set nodes
Use the index by default. (Jacques)
- [x] T92312: Warnings when unsupported geometry is passed into a node.
- Other todos:
Add Image to switch node. (Johnny)rename some sockets from “Geometry” to something more specific (Hans)Shade Smooth should be on by default. (Jacques)Add label to empty output attributes panel (Hans)Use ID/Index in ID node. (Jacques)
