Attending: Dalai Felinto, Erindale Woodford, Himanshi Kalra, Jacques Lucke, Simon Thommes.
Links
- Workboard
- Chat channel
- Video call - dailies at 14:00 CEST
- Design agenda and discussions - updated throughout the week
Agenda
- Planning for the week
- This is the 6th week of the current 6-8 week long project.
- The focus of the remaining weeks is to wrap up the core of curve support, viewer node + attribute processor prototype.
Design Discussions
- Attribute Processor discussion (T88703).
- ✓ How to create the Attribute Processor node?
- Adding an empty Attribute Processor is fine.
- No need (for now) for a fancy operator that creates the Processor from a node setup.
- Make it more stand out in the menu: Expose at the top of the attribute category followed by a separator.
- ✓ How to expose inputs/outputs?
- Allow creating inputs/outputs directly from the Group Input/Output node.
- ✓ Where to set the default state of inputs/outputs?
- Sidebar in the Group category.
- ✓ Should there be default sockets?
- No.
- ✓ Does the Index node work as is?
- Yes.
- The name “Index” is fine.
- Similar to Input nodes in shading nodes.
- Should be in the Input category (make header red).
- ✓ Decouple socket name from default attribute name?
- Yes.
- The Attribute node (like shading nodes) could be used to hardcode an attribute name inside the node group.
- How to handle outputs?
- Have an attribute output node.
- Could have two nodes that output to the same attribute. We don’t really have to make that work well, just show a warning or so.
- Provide input node for some builtin attributes like
position
for convenience. - Remove the “Default” option.
- Group inputs have these settings:
- Name
- Default mode (attribute, value)
- Default value
- Default attribute name
- What icon should attribute processor groups have?
- Something close to spreadsheet is ok-ish.
- ✓ Use the same node groups in geometry/shading nodes?
- Should be possible, but might not be nessessary for 3.0.
- How to deal with different node group types?
- Allow the user to organize node groups and where they are supported in the asset manager?
- Curve design tasks
T88725: Curve Length Node
- Have a node for the total length is good.
- Have spline length as read-only attributes.
T88702: Curve Deform Node
- Possibly: Handling all the splines to duplicate can be left out of this node and implemented as part of the “parallel for loop” solution.
T88722: Curve Change Direction Node
- The issue with the selection is that we need a good set of design rules for the defaults, when no-select is all or nothing.
Next planning meeting: 2021-6-7 at 14:00 CEST on geometry-nodes on blender.chat.
